TPS setting wacky!!!
Old 03-14-2014, 02:19 PM
totalchaosyota92's Avatar
so i just installed a new tps on my truck and when i jump the yellow connection on the driver side fendere well the truck still does not drop idle... i cannot get this motor to run perfect, i hate going to mechanics but im contemplating it now.
with the plug jumped i set the timing at -5* Before TDC, and when i unplug the jumped connection it stays at -5* before TDC. its supposed to more to around -12* before TDC.
Truck is an 84 pickup 22RE
I also get a pretty wicked wobble in the shifter when driving and it mellows out once i push the clutch in.
ive read just about every TPS thread on the internet and still can get this thing to time correctly.
Please help before i go spend a couple hundred bucks at a shop
Old 03-14-2014, 02:50 PM
wyoming9's Avatar
Red face
Maybe your check connector is corroded have you cleaned it??
It can be corroded and you can not see it with your eye .
So the truck won`t idle so you can`t check your Throttle Position sensor?
That has really nothing to do with timing.
Old 03-14-2014, 10:24 PM
Punchy's Avatar
Am I the only one that got confused with the negative switch used in the degree number before TDC?
I have always use +, Some may use it different.
Blamalam
03-12-2022 07:34 AM
accuracy
08-30-2015 09:47 PM
Blamalam
08-16-2015 12:29 PM
jetpilot
08-15-2015 06:48 AM
Sidherish
08-03-2015 07:17 PM
Quick Reply: TPS setting wacky!!!
