tps adjustment
Old Oct 6, 2006 | 04:07 PM
surfcaster's Avatar
tps adjustment
I am having a hard time figuring out how to readjust my tps. I have done searches and cannot find exact directions for my throttle. 3.0 6 cyl 91 4runner. Please help as I am idling tween 100and 300 rpm slow at idle in park/neutral and in gear. Btw I went to a new cat, cherrybomb turbo 2 and 2.25 pipe. -200$ parts and labor Much nicer sound and flow. I usually hit a half tank mark with around 100-120 miles depending on conditions I hit 130 with mixed conditions. with old plugs. I just changed them and found no probs with the plug condition. Whew! also how do you adjust the little plunger valve thing:pat: that stops the throttle at let off? thanks I have searched ...
Old Oct 6, 2006 | 05:28 PM
MRunner's Avatar
wow when I searched, I found dozens of threads (a couple per week) with valuable tps adjustment instructions and tips for the 3vze... like this one:
https://www.yotatech.com/forums/show...&highlight=tps
also, check out the link in post #7
Old Oct 8, 2006 | 07:43 AM
ripple's Avatar
http://www.4crawler.com/4x4/CheapTri...l#Introduction
This is the link that worked for me. I used the adjustment advise at the very end. Good luck.
Old Oct 8, 2006 | 07:47 AM
ripple's Avatar
I used the adjustment advice at the end and it worked really well. My resistance reading was higher than 2.3k but it still worked.
Old Nov 11, 2006 | 02:56 PM
highway74's Avatar
I just installed a new TPS in my 94 3.0 truck. I couldn't get the exact values in ohms as in the 4crawler link. I instead went with the factory service manual instruction of no continuity with 80mm feeler and continuity with 50mm feeler with multimeter connected as described. My idle doesn't change when I jump the diagnostic terminals with engine running, but the timing does changes approx. 3 degrees with terminal jumped/not jumped. It is timed dead on at 10 deg. jumped at idle and runs smooth. Any thoughts?
Old Nov 12, 2006 | 06:15 AM
highway74's Avatar
Any thoughts on this guys?
Old Nov 12, 2006 | 09:16 AM
MRunner's Avatar
I had to go off the service manual too because I couldnt get the <200 reading.. it was either continuity or no continuity. Thought it was my multimeter so I bought a nice one. No difference in readings. My 3.0 behaves the same as yours-
Originally Posted by highway74
... My idle doesn't change when I jump the diagnostic terminals with engine running, but the timing does changes approx. 3 degrees with terminal jumped/not jumped. It is timed dead on at 10 deg. jumped at idle and runs smooth...
Old Nov 12, 2006 | 11:50 AM
highway74's Avatar
Thanks for the reply MRunner, I guess it's adjusted as it should be everything seems fine otherwise, same with yours? I went back and tried adjusting again, same result, I gave up and figured it's about as good as it's going to get. I had the same problem with old TPS, which is why I bought a new one, money down the drain!
Old Nov 12, 2006 | 11:23 PM
MRunner's Avatar
yeah, exact same thing here... new TPS, then multimeter. Mine seems fine, just the idle doesnt change when the diag. terminals are jumped.
Old Nov 13, 2006 | 08:07 AM
highway74's Avatar
As long as everything else is in check I guess we're good. Thanks man.
zytra
Jan 24, 2019 03:16 PM
ZGjethro
Jun 7, 2017 11:04 PM
the_supernerd
Oct 1, 2015 09:20 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
dbollier123
Sep 29, 2015 05:23 PM
