Toya shut off
Old 04-17-2013, 09:21 AM
hebrewyota's Avatar
Toya shut off
I was driving the other day... Went to turn on the headlights and the truck shut off... It's acting like it isn't getting any power but the battery test fine... I checked the fuses and nothing was bad there.... What's the next starting point?
Old 04-17-2013, 06:36 PM
rbuchmann's Avatar
Have you had your Alternator tested to see if it is putting out?
Old 04-18-2013, 06:27 AM
Co_94_PU's Avatar
Disconnect the head lamps at thier plugs to verify it's not a short in the wiring. Granted the fuses should pop when this happens but they don't always. This is a simple check that requires no tools.
You need to check the battery voltage under load, eg headlamps and accessories turned on. Once the voltage drops below 9v the computer shuts down.
The alternator inspections are also in the manual. Link
Autozone or another parts store can do the load tests for the battery and alternator but you'll have to remove them to plop them on the counter for them.
Old 04-18-2013, 06:28 AM
Co_94_PU's Avatar
Double posted, threads need merged if a MOD spots this
https://www.yotatech.com/forums/f116/91-toyota-267966/
splangeland
04-06-2024 08:14 PM
Corvoid
12-11-2015 11:21 AM
voiddweller
09-28-2015 11:21 PM
runnermedic
13
09-21-2015 05:20 PM
SCZIG
09-20-2015 09:00 AM
Quick Reply: Toya shut off
