| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
tips on better searching this site/backspacing question
__________________
94 pickup trail rig/3.0, & 96 tacoma stock. |
#2 (permalink) | |
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
try "SAS rim backspacing"? I just did that and got seven posts.
Try using terms relevant to your query but ones that are not too vague to cause excessive replies. If you don't get enough results, like you're being too specific, try adding or changing terms like "wheel" instead of "rim". The search results will include posts that include all of your words.
__________________
Quote:
Insomnia: it's a way of life.
#3 (permalink) |
Staff
The reason for the seemingly unrelated results is mainly due to members naming their threads incorrectly or too vaguely.
A lot of times, there could be a thread about what kind of shocks to use and that thread ends up talking about wheels and backspacing. Also, members will sometimes post up with titles like, "HELP ME NOW!!!" which does not good at all when trying to search. I try and go through and rename threads that I see like that hoping it will help people down the road when they try and search - who knows? You can have it search either posts or thread titles. If you want to search for any thread with "backspacing" in the title, just select that option. If you want it to search every post on the board for "backspacing" then select that option. I usually pick a few keywords, for example if I'm searching for mods for a 3.4L V6. I would search for, "5VZ 3.4 mods mileage." Or something similar. In your case you could try searching for, "SAS backspacing wheel pickup." If you notice right above the list of results, it will have all the keywords you requested separated by commas so you can see what exactly it searched for. Sometimes common words will be omitted to aide in more relevant results. Hopefully that helps you a little bit, give it a shot and see what you can come up with. I appreciate you asking for help instead of just saying you tried and for us to leave you alone about it. Fink
__________________
1985 4Runner 22RE 4WD "Ratchet" 2007 Tacoma Double Cab SB 4x4 V6 TRD Sport AR-TTORA "My work number is 9-1-1." Last edited by 4x4Fink; 03-03-2009 at 02:12 PM. |
#4 (permalink) | |
alternately try using google and use the "site:www.yotatech.com" qualifier so Google limits its search to "www.yotatech.com"
for instance: on Google.com search for "SAS rim backspacing site:www.yotatech.com" (without quotes, obviously) here's the link for that search on Google: http://www.google.com/search?hl=en&q...h.com&aq=f&oq=
__________________
#5 (permalink) |
Staff
![]() Google bots are on here 24/7 indexing everything for easier and quicker searching on their site. Try both and see what you get. I'm seeing a Searching tips Sticky in the making here... Fink
__________________
1985 4Runner 22RE 4WD "Ratchet" 2007 Tacoma Double Cab SB 4x4 V6 TRD Sport AR-TTORA "My work number is 9-1-1." |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| backspacing question? | ohioyotaguy | 03+ 4Runner/GX470, & 05+ Tacomas | 3 | 11-19-2008 06:21 AM |
| Backspacing question | crbocaj125 | Newbie Tech Section | 14 | 05-02-2007 07:29 PM |
| backspacing question | BamaT4R | Newbie Tech Section | 2 | 04-09-2007 02:15 PM |
| Question about OMEs, didnt find anything by searching | tombothetominator | 86-95 Trucks & 4Runners | 25 | 07-16-2006 04:37 PM |
| backspacing question??? | YeloSub7 | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 08-27-2005 04:42 PM |
