? on timing lights
Old 10-12-2007, 02:55 PM
MRecio's Avatar
? on timing lights
I want to do my timing but i dont got the cash to spend on a nice snap on or other nice timing light.. do the cheap 40 dollar ones at like kragen and those kinda stores still provide accurate readings for setting the timing? if yes i need to go to the store LOL.
Old 10-12-2007, 03:00 PM
MRecio's Avatar
http://www.partsamerica.com/ProductD...egoryCode=3390
long link but that is the one i was looking at from kragen just dont know if its worth it cuz i want it to be accurate i just dont care about all those extra gismos some of the others do.
Old 10-12-2007, 03:11 PM
n4ynu1010's Avatar
Timing Light
It should be accurate , its just a inductive pick-up that fires a light at the same time the plug fires , for the most part the more expensive then the longer it will last , better materials , I have one (Mac) from 20 years ago , still works like a charm .
So dont sweat the money so much but don't go dirt cheap , get the Kragen (never heard of that hehe) , it should work fine .
Old 10-12-2007, 03:12 PM
ozziesironmanoffroad's Avatar
just to check your timing, a strobe light would work. ACCURATELY. all you do is find the notch in the bottom pulley, mark it with whiteout, and go from there.
Old 10-12-2007, 07:25 PM
n4ynu1010's Avatar
Timing Mark
Usually I have found if you just clean it ............the mark is there just covered with 5 years or more of grime , I used a old toothbrush and some "Mean Green" cleaner and presto ....white mark is back , when I have had to mark them I would use epoxy enamel touch up paint for stoves and ranges , comes in a little bottle with a little brush .
Old 10-13-2007, 04:46 PM
89 toy's Avatar
pawn shops have great deals on used snap on, mac etc timing lights
Old 10-13-2007, 05:04 PM
MMA_Alex's Avatar
the cheapo light should work the same. it wont have the special features, and usually wont be as bright so you might not be able to use it outside when its sunny, but it should still be usable.
Old 10-13-2007, 05:05 PM
dcg9381's Avatar
If you're going to buy more than a basic timing light, get one that does inductive RPM and can offset (delay) the strobe... You're looking at less than $90.
I appreciate good tools, trust me - and buy brand names (like Makita) - but I'd never drop the kind of change you're talking about just to get that SnapOn brand... I seriously doubt that they actually build that tool anyway.
Old 10-13-2007, 05:08 PM
longhungsilver's Avatar
where is this pawn shop?????
Old 10-13-2007, 05:09 PM
n4ynu1010's Avatar
HEHE , might be your neighbors but hey you got a receipt ............right LOL
06-01-2021 01:51 PM
Kalihi,HI
07-09-2015 04:29 PM
skoti89
07-06-2015 07:45 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: ? on timing lights
