Timing chain grind.......
Old 05-16-2013, 11:09 AM
woodyth's Avatar
I have had this noise since I bought the truck 2 years ago. Just recently it has gotten worse. It used to be my sign that i was low on oil, it would get worse but when I'd add a half a quart, it would go away. Now it's the constant grind, so I think it's time to tear in to it. Is it better to go to Toyota for these parts, or a place like lcengineering.com? I have never done one of these, so this will be an "experience" to say the least. ANY advice would be GREATLY appreciated!
Thanks,
Woody
Old 05-16-2013, 02:49 PM
stanprophet's Avatar
Just in luck just posted the pictures of the one I did today.
https://www.yotatech.com/forums/f116.../#post52077789
Parts go to EPN also known as engnbldr on ebay for the parts, I found it cheaper through his web site than ebay.
http://www.engnbldr.com/
You can pull the valve cover gasket and make sure the drivers side guide is broken, if it is it is time.
Old 05-18-2013, 05:41 AM
woodyth's Avatar
any issues with parts from there?
Old 05-18-2013, 01:41 PM
Nope, fit and finish were great. The tensioner is OEM manufacturer, everything seemed to be better quality than the average parts store parts. But the price is much cheaper.
Old 05-20-2013, 06:03 PM
woodyth's Avatar
parts ordered guy was nice enough. put up with my 20 questions lol 149.99 not bad!
Old 05-24-2013, 09:27 PM
woodyth's Avatar
Chain replaced. water and oil pumps also. I'm AMAZED at how simple it was.... I just followed the instructions here:
http://www.4crawler.com/4x4/CheapTri...ingChain.shtml
Great write up step by step!
Next is the clutch in 6 weeks................
Old 05-25-2013, 05:10 AM
jumper_bob's Avatar
Hi Woody, I also just did that same repair using the engnbldr front end kit ($149) and the same instructions as you. Time consuming, but not difficult.
I just read another thread and realized that I didnt use any sealant on the timing cover gasket; everything I used seemed to fit well and snug and I havent noticed any leaks yet; hopefully I wont need to tear it apart and put a new gasket in with sealant. Did you use sealant around that gasket?
Old 05-25-2013, 08:54 AM
woodyth's Avatar
I didnt use any, just on the corners on top and along the oil pan on the bottom......
Old 05-25-2013, 05:16 PM
woodyth's Avatar
Maybe someone with more experience can chime in on this!?!?!??!?!
Old 05-25-2013, 05:21 PM
Toyota~Boy's Avatar
I've always used sealant on every inch of the timing cover. If not then I almost grant you it will leak. Or mine always did.
Old 05-27-2013, 06:08 PM
woodyth's Avatar
I'm gonna keep a close eye vs tearing it all down again......
09-04-2015 09:27 AM
thefishguy77
07-30-2015 10:59 AM
razorman8669
07-12-2015 12:13 PM
Quick Reply: Timing chain grind.......
