Timing advancing
Old 08-01-2009, 10:46 AM
shftatsix's Avatar
Timing advancing
Im trying to set my timing by ear and had a quick question, after you jumper the Te1 and E1 and the idle smooths out at the lower rpm does the engine rev when you advance or retard?
Old 08-01-2009, 11:53 AM
Team420's Avatar
Usually, rpms increase(slightly) when advancing, and drop when retarding. Its really best to set your timing with a light...
Old 08-02-2009, 05:40 AM
TNRabbit's Avatar
There's a whole process; google "toyota factory service manual" for a '93 FSM.
Old 08-02-2009, 07:34 AM
Team420's Avatar
better yet...cuz google is so difficult.... heres the link.
http://www.ncttora.com/fsm/1993/index.html
Old 08-02-2009, 03:01 PM
shftatsix's Avatar
OK so with timing light on number 1 plug, Te1 and E1 jumpered at 750 idle. This is what i have:
When i bought it, the dist was rotated fully advanced. That is the position its in now. How could i fix this?
Old 08-02-2009, 03:21 PM
Teuf's Avatar
timing chain off a tooth?
Old 08-02-2009, 04:02 PM
shftatsix's Avatar
I think it was, i took out the distributer and rotated it one tooth. Got the timing to half way between the 5 and 8 mark, runs soooooo much quieter now. thx for the help guys.
The PO probably replaced the dist and forgot to check the timing, hopfully that will help my crappy MPG
Old 08-03-2009, 03:07 PM
Teuf's Avatar
good to hear, good luck.
jbv808
08-06-2021 04:47 PM
icentropy
09-16-2020 02:47 PM
mskalmus
05-28-2017 07:51 AM
MTLroadierunner
07-06-2015 12:17 PM
karbin
07-05-2015 11:37 PM
Quick Reply: Timing advancing
