Timing
Timing
Hello, so just just installed a new re manufactured 3.0l in my 94 runner,
So I was have trouble getting the timing correct do I bit the bullet and took it
The our local auto shop that works only on Honda and Toyota. I said please get the timing correct, so they worked on it for three day and for the life of them
Could not get the timing to spec, the only way for them to get it to run
Normal was to set the timing at 30degres witch is way off spec, they reset the timing belt and removed the distributor 6 times they finally gave up .
So any thoughts on what my problem is with the timing.
Thanks
Thanks
FRANCOARMANI
10-09-2015 01:27 PM
_Nicco_
09-21-2015 03:06 PM
FS[SouthEast]: 1992 4Runner with 3.4 5speed $2000
sphealy
09-03-2015 07:55 PM
