is there a "plug and play" AFM out there????
dude you on the fine line it has not blown up nore melted
that is where you are getting you power from a leaner running motor
what you air ratio is i have not clue my guess would be 17 maybe who knows
you all so have knock sensor in there to kick down timing to prevent pinging as well
I must confess that I'm unsure why you believe that the Supra mod is a bad idea. Perhaps some dyno numbers from what you've done on the 22re would help convince me that something that has been done for years is a bad idea. I've looked at dyno readouts for this mod and the hard numbers show improvement, it's not much but it's there. My biggest concern when I did this (twice) was to improve throttle response, those of us that get out and do things instead of "web wheeling" like to be able to "blip" the throttle and go over a problem area, I also was concerned about fuel milage and that improved also although only a little.
I think maybe you and I are in disagreement about the wrong things here. I know the mod works, you look online for crap that doesn't. I have a Tornado intake fan for sale if you're in the market?
Just kidding.
Shall we agree to disagree for the time being so this thread can still be used for something besides argument? (<---- you really need to read and understand this part)
edit, I forgot this part..................
Efi 101 i am going to say this once and only once
i am going to make this easy
the stock afm\ecu runs the motor Rich for reliability
the supra afm is bigger let's more air in with out the ecu know it is there
the stock ecu is tuned for the smaller afm ( timing/injector dwell/injector size/fuel map )
the supra afm lets in more un metered air that change's the a/r ratio that stock ecu did not know it was there aka fooling the stock ecu
what does this end up with not sure never had this combo on dyno can be good can be bad could be in limp mode but lean enough for it to run well i don't know
same thing for mk3 supra owners when they do the lex 1uzfe v8 karmvortext
afm more air so you have to do a injector upgrade to prevent leaning out on boost
so they stick the stock 440's and go to 550's
this all so changes the fuel cut to higher rate
the 02 sensor is not wide band dude it's just narrow band o2 sensor
it's just there to tell the car what is going on as in open loop or closed loop
but can't do every thing the knock sensor is the main controller of this
there is alot of info on ecu tuning and you learn some thign new every day
i not the greatest still take me some time to get stand alone up and running from scratch
every year ecu's just get smarter smarter and wont work with most piggy back apexi hks ect
so in the end you have to do stand alone and if not per calibrated for your truck/car you will get dead dash or the auto wont shift right ect
these will very with car's and truck's
but the 22r is a caveman you can trick it all day long and it will still run and not throw any code's ect
if you say i am lieing go read a book
ps i have dyslexia and hard for me to spell thank god this forum has spell cheaker
#25
3 VZE has another option from the 24 valve v6 camry motor. IIRC it's the 91 Camry. I bought one and haven't installed it yet.
I can get the part #'s for you when I get home.
#27
no prob dude
a good idea would to find out how big the injectors are in the 82 supra i don't remmber off hand (think 340?)
this will give you an idea on how much you are fooling the ecu
if it's not much you should be ok and might be able to play with timing still and bump it up a notch or 2 with out pinging
and if you are pinging you can try a higher octane gas to fight this or just lower you base timing
#28
well just mesher it out you find out if it is upgrade or down grade same with injectors
if i was you guys i would just install this and throw that stupid afm away should work with the 22r as well
i was going to do this but i gonna do motor swap instead
oh yea it supports boost as well it's cheep and does alot
and you can go map or run hot wire maft
http://www.maftpro.com/
#29
VAFM Swap
https://www.yotatech.com/forums/f116...-think-183463/
