THIS is a stupid question....cooalnt for radiator?
#42
People need to stop hijacking threads....
#43
I found this article last night (while posting in another thread) on electrolysis. Good explanation.
http://www.drivewerks.com/Newsletter/vol-7.htm
Unfortunately, the electrolysis process works in a similar way, zapping bits of metal in proportion to the amount of electrical current passing through the coolant. A poorly grounded starter can literally destroy a radiator or head within a matter of weeks, depending upon how often the car is started. A smaller current drain, like an electric cooling fan, may slowing erode components over many months.
#45
I'd say hose water isnt going to be a big thing as long as there arent alot of metals or salts in your water. if its city water it should be fine for a year.
As to my earlier comments about which antifreeze its not that important with Domesitic engines but with import engines especially Toyota it can be important to use the correct antifreeze. I have read several articles about the effects of using non toyota red in toyota engines and the fact that it erodes the metals in the engine. According to the article i read this is because of the specific formulation of the aluminum alloy that they use, for some reason it is particulary vulnerable to errosion from other types of antifreeze.
Ill see if i cant find the article again
#47
BTW, are you referring to the Dexron crap?
#48
https://www.yotatech.com/forums/f123...oolant-114994/
It's very expensive, about $30/gal.
#55
Yeah its suppost to last a long time, which could make it reasonable over time. But a coolant leak could get expensive. I've gotten pretty good at catching and filtering the coolant after all my cooling system testing that required draining the radiator multible times.
scott90
10-04-2015 09:21 AM
