strange leak around thermostat area? block leak?
Old 10-02-2010, 07:40 AM
customdrumfinishes's Avatar
i have a water leak near the thermostat housing, i thought it was the thermostat housing leaking but after looking it over well its not the thermo cover.
i need to know if the small hole in the pic is a possible leak point, i could see water coming out from this area but im not sure if its from the hole or above or behind it.
hard to see in there when the thermo cover is on the truck.
pics below show what im talking about, has anyone else had a leak like this before? i thought it may be the water pump gasket but not sure about that either.
1995 4runner v6
Old 10-02-2010, 10:02 AM
MudHippy's Avatar
What you have circled there is called the water pump weap hole. When the pump shaft seal fails the coolant runs out there first, instead of onto the timing belt. Which would ruin it. There's no way to replace the pump shaft seal. Which means...
New water pump time! And that means the timing belt is coming off any way, with a buch of other things too.
Have fun!
Old 10-02-2010, 11:35 AM
just had the timing belt replaced with the water pump 4 years ago but im sure its the rust in the pump and system that has done this.
thanks for the info! i wont be replacing the pump myself though not worth the stress lol.
Old 10-02-2010, 01:35 PM
myyota's Avatar
When you have the water pump replaced use an OEM replacement, it will last longer than four years. Also taking better care of your cooling system will go a long way in making the water pump and head gaskets last on a 3.0.
Old 10-02-2010, 02:47 PM
the pump is a toyota pump not a knock off, i know how those autozone parts are they last a year if your lucky.
94whiterunner
9
09-22-2015 07:28 PM
09-04-2015 09:27 AM
jjrbus
07-19-2015 02:06 PM
rushw
07-18-2015 01:46 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: strange leak around thermostat area? block leak?
