Stiff shifting
Stiff shifting
Im having trouble getting into just about every gear. When i put the clutch pedal to the floor in first, it is engaging just a little and the car will move very slowly. Is my clutch going out?
There are a few things to check. Master clutch cylinder, the slave cylinder, or its the infamous clutch bracket fatigue.
Check this link for fatigue issues with the clutch bracket.
https://www.yotatech.com/forums/f116...fatigue-32667/
Okay well i check both master and slave cylinders for leaks-nothing, had someone engage clutch while i looked and slave-it moves in and out of bell housing, and the clutch bracket is intact and functional. Whats going on? Could the rod just need to be adjusted?
punks_is_4x4
02-26-2016 04:29 PM
