Sticky RPM and surging
Old 02-23-2010, 11:47 AM
prolite1's Avatar
Alright so I have an '88 regular cab with the 2.4l 22re that is fairly new to me and i need some help. Noticed it driving home from work the other day. I was cruising along in 3rd and let my foot off the gas and instead of slowing down the truck kept right on going like it was on cruise control. Before you ask, I have the base model without cc. It doesn't do it everytime but enough to where I am concerned. Also I notice that when it is in gear and I push the clutch, to coast to stop sign for example, the engine surges, revs up and down, a few times. I'm thinking maybe a throttle position sensor. Any help is greatly appreciated, thanks!
Old 02-23-2010, 12:00 PM
Junkers88's Avatar
Sounds like the dashpot (not actually on/in the dash) is sticking. Do a search for "dashpot". It may answer your questions.
Old 02-23-2010, 02:15 PM
Flash319's Avatar
Floor mats..........
Old 02-23-2010, 02:58 PM
Junkers88's Avatar
Too soon..... just too soon....
Old 02-23-2010, 03:09 PM
Flash319's Avatar
I had to, the timing was perfect!
Check your dashpot like was mentioned and check for vacuum leaks.
Old 02-23-2010, 03:31 PM
Junkers88's Avatar
Does is surge when the brake pedal is pressed? If so then the idle is too high. If the dashpot is sticking then this will cause the idle to stay up higher than it should be and with the brake pedal pressed it will surge.
Old 02-24-2010, 08:23 AM
prolite1's Avatar
Thanks for the replies. It must be the dashpot because I just bought brand new high performance floor mats last week! I've never even heard of a dashpot before, never the less time to go take a look.
Old 02-24-2010, 08:32 AM
Flash319's Avatar
I bet you got like 20 more HP out of those mats........
Old 02-24-2010, 08:34 AM
prolite1's Avatar
better gas mileage too
Old 02-24-2010, 06:12 PM
Jay351's Avatar
Mine does the same thing, often too..
Never been able to figure it out. Seems to go away if I spray cleaner in the TB and scrub it.. never much gunk though.
My dashpot seems to move smoothly aswell, I even lubed it...
Old 02-24-2010, 06:19 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
lol...
Lube the cable, check the spring... Check for vac leaks... Maybe there's so much gunk behind the butterfly it's holding it slightly open...
Old 02-24-2010, 06:33 PM
peow130's Avatar
My carbed pickup never has these problems
Carb: 1 EFI: 0
Old 02-24-2010, 06:56 PM
Jay351's Avatar
haha, go up that hill! Ohhhhh...... efi +1000
Old 02-24-2010, 07:23 PM
lol... of course he says that now... wait till all the carbs and all the parts for them are obsolete...
or his carb just starts giving him problems...
Better knock on wood, peow!! If I know the Toyota gods, they're planning your demise as we speak!
Old 03-21-2010, 12:06 PM
hayden.armidillo's Avatar
where could i get a new dashpot for cheap?
Davebarbier
11-03-2015 03:28 PM
Ditch Doc
10-27-2015 03:20 PM
Flightguy
10-02-2015 05:34 PM
Jdgarrison
10-01-2015 05:22 PM
Jdgarrison
10-01-2015 02:11 PM
Quick Reply: Sticky RPM and surging
