Steering Gearbox
Old 08-18-2008, 06:00 PM
T-1000's Avatar
Steering Gearbox
My power steering gearbox leaks like crazy from the input shaft.
I have a new seal on order from Toyota, will that fix the problem? Or should I just pony up the ~$200 and get a reman?
Old 08-19-2008, 04:06 AM
WFO
WFO's Avatar
I went to the dealership to get this part and they told me I had to buy the back portion of the gear box. Something outrageous like $700. I put a bottle of trans stop leak and that fixed it for a couple months. Now it leaks so Im gonna buy a re-man.
Old 08-19-2008, 08:20 AM
Elvota's Avatar
Here ya go:
https://www.yotatech.com/forums/f107...-boxes-151981/
Old 08-19-2008, 08:23 AM
dirtoyboy's Avatar
What kinda fluid are you using? ATF or steering fluid?
Steering fluid WILL make your box leak...I've seen a box with new seals leak within hours using steering fluid....
Old 08-19-2008, 03:45 PM
T-1000's Avatar
It came with a bottle of PS in it, so I used that for a while, I think it greatly exacerbated the leak.
Old 08-19-2008, 03:46 PM
T-1000's Avatar
Originally Posted by Elvota
Thanks for the link.
Old 08-19-2008, 03:57 PM
abecedarian's Avatar
T-1000
you may be okay flushing everything out then changing the seal you were going to change, then just using ATF.
See how that goes before you ante up for a new box.
Old 08-19-2008, 07:21 PM
T-1000's Avatar
Originally Posted by abecedarian
T-1000
I'll let you know if it works, the seal should come in tomorrow.
DEXRON II this time around.
ladybugRC
458
08-21-2020 10:41 AM
live4soccer7
05-11-2016 06:52 PM
scott90
10-04-2015 09:21 AM
ktm192k
10-01-2015 08:47 AM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: Steering Gearbox
