Steering Center link?
I have a 1987 2wd Toyota pickup. The ball joints on my center link is bad. Do i have to replace the whole link or can I just replace only the ball joints? If so how do i. Ty for help
Before you do that, call the dealer with your VIN and make sure it's not subject to the relay rod recall. (I don't recall the applicable years.)
And since Toyota felt it worth a recall to put in a beefier one, I'd spring for the $200 to go OEM. http://www.toyotapartsoverstock.com/...chString=relay
Staff
My 87 two wheel drive didn't fall under the recall as well. Toyota should of recalled them as the Relay Rod is a poor design. The passenger side is the side to really check for on these two wheel drive trucks.
Yes, you are correct. http://www-odi.nhtsa.dot.gov/acms/cs...5V389-7917.PDF (1089-1995 4WD).
Up&Down
08-05-2015 06:20 AM
terminator
07-27-2015 07:13 PM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
