Starting problems when warm.
Old 08-03-2011, 10:43 PM
Philly4runner's Avatar
Cool Starting problems when warm.
Hey guys I've been having a problem with my 4runner starting when its warm. I have replaced the temp. sensor on the manifold, the cold start injector and re adjusted the tps. My mechanic just rebuilt the cylinder head with LC engineering parts and re adjusted the timing. I have new plugs fuel filter plug wires cap and rotor ect. I had this problem before and after the head rebuild. Its a 22re in a 1992 4runner with LC engineering header bored out throttle body teflon gaskets cam 1mm bigger valves rocker shaft and all the other components to the head came from them as well. When it was assembled my mechanic had the head ported and polished and the intake runners port matched. The motor is now much more powerful I just wish it would start on the first try when warm instead of me cranking it three or four times before it starts. Any information would be appreciated.
Old 08-04-2011, 08:07 AM
fdp101452's Avatar
Coil?
Old 08-04-2011, 10:42 AM
Cool
How do I tell if the coil is bad? It starts fine when cold and sometimes it starts right up when warm. But most of the time when warm it has trouble starting.
Old 08-04-2011, 03:41 PM
Cool
:p issed:
Old 08-04-2011, 04:16 PM
jeetS's Avatar
When you replaced the temp sensor and csi switch did you do it with the updated parts as per the TSB?
Old 08-04-2011, 06:43 PM
I'm not sure jeetS please explain.
Old 08-04-2011, 06:44 PM
The csi came from LC engineering and the temp sensor was from the auto parts store.
Old 08-04-2011, 07:40 PM
jeetS's Avatar
I have the TSB in a pdf...not sure how to post it...but there are updated part#s for the CSI time switch and the temp switch #2...which is on the t-stat housing.
The tsb is supposed to fix heat soak start issues.
Old 08-04-2011, 07:58 PM
Thanks dude! Just copy and paste it to the post control c to copy and control v to paste.
Old 03-06-2012, 12:28 PM
StewsRunner's Avatar
Hey this is kind of late but I am having the same problem. My guesses were the ECT sensor, cold start injector and the wire between the battery and starter. It's getting spark and fuel, only does it when its warmed up or in the heat. It starts right up in the morning but then cranks and cranks when warm. The coil and the igniter check out. . .Any ideas?
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
Regency
20
01-03-2020 07:43 PM
Jnkml
07-06-2015 01:20 PM
jmc88runner
06-18-2015 03:39 PM
Quick Reply: Starting problems when warm.
