starting issues
Old 06-05-2008, 06:33 PM
Toy-SkiTzo's Avatar
starting issues
first off 1986 toyota 4runner 22re
my truck is having some starting issues
it needs to crank for 10-15 seconds befor it starts up and it only started after i fixed the fuel line that blew, changed the fuel pump, pressure regulator, and filter allready in a attempt to fix it and the tank has pressure in it (you can hear it when you losen the cas cap)
any ideas? its really starting to piss me off and it seams to be getting worse the truck with stumble before it finally starts now
Old 06-05-2008, 06:43 PM
abecedarian's Avatar
check for vacuum leaks.
Old 06-05-2008, 07:41 PM
just a 22re's Avatar
cold start switch and or injector maybe?
Old 06-06-2008, 01:57 AM
TORTIS's Avatar
this is way out in left field, but try resetting the ecu.
Old 06-06-2008, 02:15 AM
scuba's Avatar
i would try checking the cold start injector and the CS switch
as said above
Old 06-06-2008, 04:06 AM
Toy-SkiTzo's Avatar
i was thinking the CS swich as well but i cant find one. is there a way i can test it?
Old 06-06-2008, 06:07 AM
Junkers88's Avatar
Does the fuel rail hold pressure? If not then you'll need to find the leak (mine was a bad O ring on an injector). What happens is the fuel rail needs pressure to "pop" the injectors for start up. No pressure, no "pop", no start.
Just a thought.
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
Regency
20
01-03-2020 07:43 PM
coryc85
09-09-2015 06:24 AM
Avenged
07-09-2015 07:55 AM
Quick Reply: starting issues
