starter problems
You have classic voltage drop to the starter solenoid symptoms. Put in the hot shot relay (or simply any 30A relay) and your truck will start like its on viagra.
To run the truck without the ignition you need to power the solenoid wire direct from the battery using a jumper wire.
ZONAYODA
07-13-2015 07:17 PM
