Speedo/Tach cluster ??
Old 12-25-2006, 02:20 PM
tkm433's Avatar
I have a 94 22re 5-speed and want to upgrade to the gauge cluster with the tachometer.
Is there a difference between the clusters from a v6 or a 22re or are they the same?
Also does it make a difference if the donor cluster is from a automatic transmission truck?
Is the tach marked in any way to let me know if a cluster is for a 4 or 6?
If there is a differnce is there a way to tell if the tach is from a v6 or 4cyl?
I know that I will need to change my oil sending unit or risk burning out the oil guage and that also I need a cluster designed to use a electic drive speedo but any other help is wanted.
Old 12-25-2006, 06:57 PM
MMA_Alex's Avatar
Try using the search. A lot of this information has been covered before. Search for "gauge cluster" or something like that.
I know there were issues with the oil pressure showing up as too low when people swapped in the gauge clusters with the tach, but I cant remember exactly what was said.
Old 12-26-2006, 06:53 AM
spudrunner's Avatar
Try to get a cluster out of a 4cyl. You're tach will be off if you get one out of a 6. Not sure about auto and manual, but I would try to stick to the same. My '91 v-6 manual redlines at 5800. I just upgraded my '88 22re to a 22rte cluster that redlines at 5600. You'll have to change out the oil pressure switch also. Hope this helps.
Old 12-26-2006, 09:25 AM
tkm433's Avatar
Originally Posted by spudrunner
Try to get a cluster out of a 4cyl. You're tach will be off if you get one out of a 6. Not sure about auto and manual, but I would try to stick to the same. My '91 v-6 manual redlines at 5800. I just upgraded my '88 22re to a 22ret cluster that redlines at 5600. You'll have to change out the oil pressure switch also. Hope this helps.
Thanks for the info!
TheBFA
02-15-2020 06:55 AM
Jdgarrison
10-01-2015 05:22 PM
87SR5justin
09-15-2015 06:48 PM
imhousing
09-10-2015 02:04 PM
Rawwdz
09-06-2015 09:03 PM
Quick Reply: Speedo/Tach cluster ??
