Speedo cable keeps breaking
Old 07-06-2014, 09:51 AM
green tacoma's Avatar
My 95 toyota tacoma Speedo cable keeps breaking where it connects to the transmission. What is causing this? Any advice is appreciated thanks for reading
Old 07-06-2014, 10:07 AM
millball's Avatar
After you have installed a new cable, does the speedo work correctly for a while before the new cable breaks?
Old 07-06-2014, 10:12 AM
JasonYota's Avatar
What exactly is breaking? That year it should be an electronic speedometer.
Old 07-06-2014, 10:17 AM
millball's Avatar
Not sure about Tacos, but my '95 5-speed 4Runner has a cable speedo.
I think that some earlier '90s' had electronic speedos, and then they changed back to cable for some reason.
Old 07-14-2014, 11:58 AM
yes but a toyota mechanic lubed it before it was installed this time and so far so good. the mechanic said that they should be lubed before installation because they get really hot when they spin thanks for the reply
Old 07-14-2014, 12:01 PM
im not sure what its called its a little metal thing that goes into the transmission that is crimped onto the cable. thanks for the reply. it has been replaced and is working good I had it lubed before installation by a toyota mechanic. he said the issue was that it wasn't lubed before installation
kawazx636
10-06-2021 03:03 PM
Truckwithoutaname
10-03-2015 03:41 PM
voiddweller
10-02-2015 07:47 AM
charlie_fong
09-27-2015 10:06 PM
Rcbc92
09-26-2015 03:00 PM
Quick Reply: Speedo cable keeps breaking
