speed sensor help
Old Sep 3, 2008 | 02:39 PM
jacumja's Avatar
speed sensor help
So after finally needing to take my 4runner in to my trusty shade tree mechanic for work, I decided to ask him why my speedometer had bounce on it and why my cruise control jumps up and down when set. His very fast answer without even needing to look was that my speed sensor was bad. I trust him and his 50+ years of experience.
My question is, how hard is it to replace the speed sensor in a 95 4runner, v6, 4wd? Can it really be that difficult, I'm guessing it's a plug and play deal. Any help would be greatly appreciated.
Old Sep 3, 2008 | 02:57 PM
DeathCougar's Avatar
Yes, its really quite easy. Located at the back of the tcase, remove just one 12mm bolt and the speed sensor will slide right out. Unplug it, install the new one, tighten the 12mm bolt, and VIOLA you are finished. Maybe 10 minute job. And thats if you take 2 beer breaks and a mandatory state authorized "rest period"
Old Sep 6, 2008 | 01:53 PM
anotherjeff's Avatar
Your wrench should have looked! You may have a cable driven speedometer. In which case, it probably needs lubricated.
The '95 4Rnr Limited that I looked at, had a cable driven speedo.
Old Sep 6, 2008 | 05:19 PM
Team420's Avatar
Really??? wow...never seen a 95 w a cable...huh. Although...I have a rearend out of a 93 runner that had 4 wheel abs.... didnt even know they made those in 93.
Old Sep 6, 2008 | 05:43 PM
abecedarian's Avatar
Most car makers do 'running changes' to vehicles. Sometimes to start the integration of a new system and at other times just to test them out.
Good luck finding a manual that incorporates those 'running changes' or those 'retrofit' applications.
Old Sep 7, 2008 | 03:15 AM
95 4runners had a cable drive speedo.
I think Toyota realized their mistake with the electronic speedo, and switched back
Old Sep 7, 2008 | 05:43 AM
Did earlier 4Rnr's have the electronic speedo?
Tanks.
Old Sep 7, 2008 | 06:39 AM
Team420's Avatar
no kidding!! Any thoughts on why this rear I have have abs sensors at each rear wheel instead of on to the carrier? The rear came out a 93, and is going into a 93, I know my 94, and other years I have had...up to 95... had the 1 sensor on the carrier...never seen one like this before...and havent been able to find any info on it.
krimsonone
Sep 13, 2024 09:33 AM
montanatruck
Feb 26, 2017 07:07 AM
ty1er
Aug 1, 2015 11:53 PM
wilbertd
Jul 6, 2015 07:39 AM
karbin
Jul 5, 2015 11:37 PM
