sold my jeep and bought this!
Old 08-12-2012, 10:35 AM
Mickeybas's Avatar
Smile
new to the forum... so about a week ago i sold my lightweight built jeep xj and bought a 93 toyota pick up truck. so far i love this truck like no other it has the sr5 motor with a fresh rebuild brand brand new toyo mud terrian 33x13.5 new dark green paint in march of this year and it has a 3 inch spindle lift with stupid ass blocks in the rear manual tranny and a marlin crawler rear bumper. and it is also straigh piped sounds bad ass, yesterday i went to go test out my 4x4 and the rear lift block snaped into 3 peices! stupid but i am going to swap that out pretty soon here and thinking of a dana 44 swap. but tell me what you guys think of this rig!
let me know what you think
Last edited by dropzone; 08-13-2012 at 10:51 AM. Reason: merged posts to get rid of extra pic code-clean up
Old 08-12-2012, 11:01 AM
JonnyBoy's Avatar
Looks like a pretty solid truck, why the Dana 44 idea? Got one laying around already? Also, confused on the spindle lift, as far as I knew the only spindle lifts out there for our gen of trucks is for the 2wd's. Did you mean ball joint spacers between the uppar a-arm and ball joint?
Old 08-12-2012, 11:05 AM
Mickeybas's Avatar
yeah a buddy of mine has a dana 44 laying around said he would give to me for a set of tires that i have i would give him. no its not ball joint spacers my friend has ball joint spacers on his truck and there not spacers on mine i am pretty sure there spindles, the front cv axle shafts are flat.
Old 08-12-2012, 11:11 AM
Luvmeye22re's Avatar
It looks like a bracket lift. I wouldn't bother with a D44 myself, Toyota axles are quite strong. It would be more work than it would be worth. If you insist on having Dana axles go with 60's...
NICE TRUCK!
Old 08-12-2012, 12:27 PM
NickMiller's Avatar
I second the bracket lift... I don't think you can do a spindle lift on a 4wd yota? Might be wrong, but I'm pretty dang sure!
Old 08-12-2012, 12:42 PM
bone collector's Avatar
Go test out the IFS and the bracket lift before you rip it out for a Dana 44. Check out Rattlewagons build thread so you know how much abuse the IFS can take..
https://www.yotatech.com/forums/f199...thread-224943/
BTW good job making a switch from the dark side of heeps...
Old 08-12-2012, 02:28 PM
yota864x4's Avatar
Nice looking toyota! I totally agree with the dana 44 idea. That's what I'm going to do when I get saved up. Its cheaper, easier to get parts for, and its stronger. I had friends that had the toyota axle and they kept destroying it! They swapped to the 44 and had a better turning radius, more flex, and stronger.
Old 08-12-2012, 02:32 PM
22RE4WD's Avatar
That's a great looking truck you got there! I'd love to hear sound clips or video of that straight pipe!
Old 08-12-2012, 02:51 PM
rbmoomba's Avatar
Good looking rig. Nice upgrade from a jeep
Old 08-12-2012, 05:32 PM
Mickeybas's Avatar
yeah i like the ifs i am not going to rip that out mabey in the future but when i was talking dana 44 i was talk about the rear in cause the tires are pretty big on this truck idk if the axle on it now can handle much more off it. it has the 30 spine i think? idk i am still trying to learn about this yota
Mickeybas's Avatar
Old 08-12-2012, 05:43 PM
James Woods's Avatar
Nice truck, the Yota axles can handle the tire, they are pretty stout axles, you wont have to deal with the axle shafts snapping at the sight of a rock like with the Dana 35 you most likely had under the XJ. There are guys on here running 40's with those axles.
Old 08-12-2012, 08:06 PM
runs-on-4's Avatar
take a look at my build thread and look at how much abuse ifs cant take.... aha first time wheeling it fully locked broke a cv, with 33's my bro shreaded his 7.5 a month after putting on 33's
Old 08-12-2012, 08:43 PM
abecedarian's Avatar
So it's got blocks in the rear. You don't like blocks? Install new leafs. Rear end problem solved.
IFS has its advantages and disadvantages. What to do boils down to what you want the truck to do.
Nice looking truck, by the way.
Old 08-12-2012, 09:04 PM
Jaino240's Avatar
Awesome looking truck. Saw this truck on CL awhile back.
Welcome to YT!
Old 08-13-2012, 06:40 AM
highonpottery's Avatar
Great looking rig! I love 3rd gen pickups. Though in an odd and vulnerable placement, I'm kinda diggin' the fuel can off the side.
^this. No need to do d44 unless you're planning to rip off your IfS at the same time. Yota (solid) axles are good up to around a 37" tire unless you have a very heavy foot and do LOTS of crawling. You'll be fine with your 33s.
Did you put on those 33s? If so, what are the specs on your wheels out of curiosity? I run 33x12.5 Toyos on 3.5" backspaced wheels and I had to do lots of pounding and some cutting to make them fit without rubbing. Just wondering how you got wider tires to fit - but then again you have a bracket lift and I kept mine minimal lift, which may explain a lot.
Old 08-13-2012, 06:47 AM
waskillywabbit's Avatar
86-95 stock rear axle will typically handle 38s easily without breaking
D44 SAS is pointless IMO. It's no stronger than the Toy SFA and causes more issues than it rectifies. Want full widths get a D60 front and 14 bolt rear.
:wabbit2:
Old 08-13-2012, 10:56 AM
Fossilized
Staff
dropzone's Avatar
How does a Dana44 improve flex over any other SA? I would pit my chromo axle equipped toy SA against a D44 with comparable tires.
A stock toy axle is already passenger side drop and kits are easier to be had for a SA swap and out of the box just as strong as a Dana 44.
Edit: Toyo MT's bring the suck, don't clean well even with wheel spin, yes I own a set...
Old 08-13-2012, 11:00 AM
yota864x4's Avatar
out of personal experience and what ive been with them in, the toyota front axle wasnt nearly as strong. his was even built up with stronger parts and couldnt hold up to the 44. i dont know how his flex changed, could have been just because he changed other things also but it was a lot better.
jasonty
41
12-23-2018 01:00 PM
montanatruck
02-26-2017 07:07 AM
09-04-2015 09:27 AM
WellsR
12
07-31-2015 03:27 PM
Yota.Jay
07-23-2015 08:08 PM
Quick Reply: sold my jeep and bought this!
