Should I replace the rear main seal??
Old 01-07-2008, 11:51 AM
mtrdrms's Avatar
I am in the process of a clutch job on my 89 4runner 3.0 and I have the flywheel off but I was wondering if I should replace the rear main seal while I have a good shot at it? It looks fine and its not leaking at all. I would be pretty upset if I put it in wrong and it leaked but I guess I would also kick myself if this one started leaking in a few thousand miles.
thanks
Andy
Old 01-07-2008, 12:09 PM
TORTIS's Avatar
no leave it alone, it will give you something to do in a couple of months.
if you don't replace it, you will hate your self later...
Old 01-07-2008, 12:13 PM
mtrdrms's Avatar
haha. good stuff.
Old 01-07-2008, 12:18 PM
Albert.G's Avatar
while your there...i hope you do... its like taking a crap and not wiping your bum...and putting on 3 layers of clothes...then putting on a snow suit...then thinkin...damm i shoud have really wiped
Old 01-07-2008, 12:27 PM
tampabayota's Avatar
trust me it is wise to do it now
TNRabbit's Avatar
x4 to the above; it's really easy at this point and it will NOT be later!
Old 01-07-2008, 12:33 PM
MudHippy's Avatar
Alright, fine. You guys convinced me too. I happen to be in the same boat and was wondering the same. Guess I better go pick one up. My clutch shouldn't be here for a day or two anyway, so I'd best take care of it now too.
Old 01-07-2008, 04:50 PM
ewong's Avatar
I do it every time the trans is out...
Old 01-07-2008, 05:14 PM
SEAIRESCUE's Avatar
Really dumb move if you don't do it during a clutch change. Clean the crank surface really good with brake cleaner and put a light coat of grease on the seal.
Old 01-07-2008, 07:08 PM
TNRabbit's Avatar
I use STP oil treatment on the seal. Stickiest damn lubricant I've found!
Old 01-07-2008, 07:51 PM
84sr5yoty's Avatar
Hell, replace the front seal on the trans too. I replaced my clutch last year and now the front seal on the trans is leaking
Oh well, what can you expect from a 24 year old seal with 200K miles.
Old 01-07-2008, 08:00 PM
CoedNaked's Avatar
Now this is BY FAR the best analogy to explain WHY you should do the rear main seal while you're doing your clutch, that I have EVER HEARD.
I would definately do the rear main if I were you.
Old 01-07-2008, 08:05 PM
YotaJunky's Avatar
Originally Posted by tortis
no leave it alone, it will give you something to do in a couple of months....
Old 01-08-2008, 03:44 AM
mtrdrms's Avatar
Well I got the seal and dam when did they go up to 28 bucks! Oh well Im off to put it in. Thanks for all the advice guys!
Andy
warrenjcarlson
07-22-2016 11:47 AM
voiddweller
19
05-02-2016 09:10 PM
jennygirl
11-17-2015 11:24 AM
Alaskan91
09-21-2015 04:39 AM
cchinny
06-25-2015 08:11 PM
Quick Reply: Should I replace the rear main seal??
