Semi stripped t-stat housing
Old 11-03-2007, 11:33 AM
Luvmeye22re's Avatar
Well through my dilemma with the cooling problems I've had the tstat out and new one in etc. One of the bolts that held it on definitly didn't belong so I've been as gentle as possilble with it but it finally gave up the ghost and stripped due to the wrong bolt being in there. Right now the bolt isn't quite just spinning in there, but by feel I can say that if I snug it enough to not leak, it's going to tear what's left of the threads out.How can I fix this? P.S. I hate previous owners.....
Old 11-03-2007, 12:14 PM
Tap and dye? I have enough cash to buy a set but I don't know what bolt to move up to and have never used a set. Any suggestions?
Old 11-03-2007, 12:25 PM
RustBucket's Avatar
Find a mechanically-inclined friend to help you if you're worried about it. Fortunately, it's soft aluminum so it will be easy to fix. Find a bolt that is bigger than the hole currently in there and just tap it with a tap that has the same diameter/thread pitch. You might even have to widen the hole in your T-stat housing.
Or if you wanted to be really slick you could helicoil it
Old 11-03-2007, 12:28 PM
Cool, I'm headed to the parts store, it willl be leaking a little bit, but it's only a few miles away......
Old 11-03-2007, 12:29 PM
Marc's Avatar
looks like I got beat
You shouldn't have to buy a set, just the one you need.
You will need a bottom tap if it's a blind hole, they're flat on the bottom, not pointed.
Do not use any lubricant if tapping into aluminum unless of course there are now lubricants available for aluminum (it's been a long time since I'be worked in a machine shop).
As far as the size it will be the 1 that corresponds with the drill bit that will just clean up the hole you've got.
Old 11-03-2007, 12:45 PM
JoKEpLaYeR's Avatar
Same thing happened to me. I found a used intake manifold on ebay for about $20.
Tap and dye might be nice for future uses too though.
Old 11-03-2007, 01:29 PM
just got back, made it without getting all that warm I got just the tap I need and two bolts so atleast I'll be sealed up again. I hate cooling issues. I'd rather do a timing chain than deal with this crap.
Old 11-03-2007, 01:31 PM
frodin1's Avatar
Heli-coil may work also. Goodluck.
Old 11-03-2007, 02:51 PM
TORTIS's Avatar
x2 on the heli-coil
Old 11-03-2007, 05:37 PM
I think I'm going to kill the guy that owned this truck before me.
Old 11-03-2007, 06:02 PM
TORTIS's Avatar
yep. the PO's can really cost you down the road.
ladybugRC
458
08-21-2020 10:41 AM
primordialbeast117
12-19-2015 12:23 PM
Davebarbier
11-03-2015 03:28 PM
hiluxinargentina
09-30-2015 05:51 PM
Odin
09-26-2015 06:56 PM
Quick Reply: Semi stripped t-stat housing
