scary thing happened to me, now questions
Old 02-22-2009, 10:15 AM
eich75's Avatar
over the past few days, my truck was makin this whining noise when i left of the gas, i just dismissed it because it always does that. but then the whining turned into like a grinding noise and i started to get scared. Then on my way home last night, i was headed down a big hill and i heard a big pop or snap or somethin. It sounded at first like a ujoint in my front drive shaft cuz it felt like it was draggin and hoppin up. So i pulled over, shut my truck off, looked around my truck and underneath of it for the driveshaft hangin down, it was still attatched so now i'm lost. It still drives and goes thru all the gears, 4x4 still works, so i have no idea what the heck happened. It drives like normal until i press the clutch or let it coast with no gas, then it feels like my wheel is about to fall off, it shakes and like goes faster than the other wheel and then bounces off something? If that makes any sense to you at all. Well any input would be great, thank you
Old 02-22-2009, 10:47 AM
rock slayer's Avatar
sounds like a cv problem but that shouldnt happen if your hubs are unlocked try havin someone drive slow so you can see if the cv axle on that side is turning
Old 02-22-2009, 10:49 AM
my truck sounded like that and turns out my cv joint wend bad ended up breaking my inner axle i now have manuel hubs instead of thos crap always in auto hubs
Old 02-22-2009, 11:15 AM
eich75's Avatar
no this is in the rear, the front stuff is fine... the noise is comin from the rear, drivers side wheel... i was thinkin possibly chipped a few teeth off the ring or pinion?
Old 02-22-2009, 11:19 AM
oh wow that sucks yeah dude i thought you were talkin about the front sorry if you dont have a broken shock mount then i have no idea:/
Old 02-22-2009, 11:31 AM
dark_fairytales's Avatar
From the way you explained the whining sound, it reminds me of the rear diff. I know from experience and so do many others on yotatech that when the diff. gets low on gear oil it likes to scream when you let off the gas. Plus depending on the possible damage to the ring or pinion your truck may still drive easily.
So for easiest of issues, drain your rear diff and check for metal in the oil, then do the same for the tranny. That is where my diagnosis would start
Old 02-22-2009, 11:36 AM
eich75's Avatar
ok, thanks a bunch!!! that at least gives me a start
Old 02-22-2009, 12:06 PM
Hayes's Avatar
check your t-case output shaft. mine is doing the same thing, unfortunately, mine is so f---ed that I have to replace my t-case.
Old 02-22-2009, 03:29 PM
eich75's Avatar
i found the problem thank god... i replaced the pinion seal over chirstmas break and i never put loctite or punched the nut so it wouldnt come back off, well, it did ha ha, with a big bang and gear lube everwhere... i dont think (aka, hope) that it hurt the ring or pinion but i plan on changing them after basics, which is only a month away, so it should be good till then... just glad i didnt explode my ring and pinion, that would ruin my day haha
Old 02-23-2009, 05:16 AM
GSGALLANT's Avatar
From the symptoms you're describing, I'd be surprised if there is no damage on your gears...
Old 02-23-2009, 05:33 AM
crolison's Avatar
he probably has done some damage, but I would just take it easy the next month on it, and regear it
oldirtydirt
02-23-2020 09:30 AM
rushw
07-18-2015 01:46 PM
icentropy
07-14-2015 10:23 AM
88runnergomas
07-09-2015 01:12 PM
Quick Reply: scary thing happened to me, now questions
