Running 35X12.50 on procomp lift kit
Old Sep 3, 2008 | 01:52 PM
krepas's Avatar
Hi,
I want to know if can run 35X12.50R15 tires on lif kit procomp 4" stage 2, right now i run 33X12.50...
Gear ratio 4.88, 5 speed, 3slow
Thanks...from Mexicali, Mexico....
Old Sep 3, 2008 | 02:10 PM
SwampThing's Avatar
Probably could. Might have to trim some fender though. That and you might find yourself wanting to get some 5.29s
Old Sep 3, 2008 | 02:21 PM
drfakoo's Avatar
If I did not understand wrong on other posts, 35´s and IFS is not a good combo...
Cheers
Facu
Old Sep 3, 2008 | 02:50 PM
SwampThing's Avatar
You'll be snapping cv's a hell of a lot easier with 35. That's and the whole 7.5" ifs compared to 8" issue.
But all that depends on how hard you wheel it.
Old Sep 3, 2008 | 02:51 PM
toyminator2000's Avatar
With 35's you'll start snapping axle shafts on that IFS if you wheel it.
Old Sep 3, 2008 | 11:28 PM
olharleyman's Avatar
Pro Comp Stage II 4" lift and 35's and I have no issues so far with cv breakage.
I did have to trim the front of the body pinch weld about 1 1/2" but still have a small rub at full lock left and right. I will be adding a set of B.J. spacers hoping to help relieve that issue Also have 0 turns on the torsion bars still set at stock and leaves the cv's near flat with very little to no angle.
I also added manual hubs and got rid of the A.D.D. not sure how much if any it helped/help's but makes the front free wheel so it doe's in the long run help the health of the cv's and front 3rd.
Had to go to 5.29's also to make up for an ass load of lost power on hill's with the stock 4.11's hope that this helps you out with your decision.
Old Sep 3, 2008 | 11:52 PM
space-junk's Avatar
hmm... ol harley man, your truck is what my dreams have been made of since i bought my 4runner... looks great...
Old Sep 4, 2008 | 12:14 AM
krepas's Avatar
i not a hard wheeler, i like more Sand dunes, in the future want to make a Solid Axle Swap but i want to buy first the tires to puch me to make the SAS a soon as posible...
Old Sep 4, 2008 | 06:16 AM
ovrrdrive's Avatar
I'm with olharleyman on this one too...
I have a Superlift 4" bracket lift, 1.5" bj spacers and a 3" body lift and have been running 36" tires for over a year now and haven't broken anything yet.
You just have to know your limitations. I don't push my truck into anything I don't think it will handle, and it doesn't make me walk. We have an understanding.
Old Sep 4, 2008 | 02:45 PM
Is that a stock paint job? I really like that blue
Old Sep 4, 2008 | 03:23 PM
rhale's Avatar
i've got the exact lift, pro-comp stage 2,on my 89 4runner with a 3" body lift and the 35's clear easily. no torsion bar change or shackle lift either. i can post pics if you want.
i would think that you should be able to clear the 35's with a slight torsion crank and a little massaging of the rear, unless you change the shackles.
Old Sep 4, 2008 | 05:47 PM
ovrrdrive's Avatar
Yep it's the stock color it was when I bought it back in '94. I just took that pic from the only angle where you can't see all of the faded panels.
A paint job is on my short list. It will go back the same color though. I really like it.
Old Sep 4, 2008 | 06:39 PM
krepas's Avatar
Please Upload pictures of your truck....
My 4runner has coils on rear maybe i need to put a spacers ....
Best Regards...
Old Sep 7, 2008 | 01:52 PM
rhale's Avatar
[IMG]http://i446.photobucket.com/albums/qq181/rhale4/DSC00874.jpg[/IMG]G]
Old Sep 7, 2008 | 01:55 PM
rhale's Avatar
sorry screwed that up the first time
Old Sep 7, 2008 | 02:21 PM
krepas's Avatar
your setup it's:
4" procomp lift kit stage II
3" body lift
35X12.50R15 Tires
your RIM size are 15X10 or 15X8, my rims are 15X10
if i put a 2" of body lift it's enough to clear this tires
Old Sep 7, 2008 | 03:18 PM
93rustedyota's Avatar
Originally Posted by krepas
your setup it's:
3" body lift
35X12.50R15 Tires
thers a guyon here clearing 35's with just a 3inch body so 4inch and 2 should be good maybe thow some bigger shackels in back and some bj spacer but see after u put it on if it doens fit
Old Sep 7, 2008 | 04:01 PM
rhale's Avatar
rims are 15X8's and yes with a 2" you should clear it fine. i have considered cutting 1" off mine many times.
Old Mar 24, 2009 | 08:59 PM
krepas's Avatar
i bought the tires and this is how my 4runner looks...
little flex...
last one
these pictures are from Sierra San Pedro Martir, Baja Califonia, Elevation 2850 meters about 9350 feet over sea level we travel from Mexicali, Mexico elevation 5 meters under sea level...
thanks
Old Mar 24, 2009 | 09:18 PM
little flex...
last one
thanks
Looks really good did you put a 2" body lift on it? any t-bar turning? Also is yours automatic or 5 speed? Never mind I see it is a 5 speed again it looks really good
