Rough Country Lift Questions
yeah the front tires rub on the black plastic bumper (whatever its called) below the turn signals but thats an easy fix its not to bad and i dont know about the pinch weld yet...
the rear rubbed pretty dang bad in the back of the fender when i flexed it so i took the mud flaps off and i think it will do the trick im also gonna lift the rear about an inch to level it out so the rear shouldn't be a problem after i install the spacers
Thanks man i appreciate it
#25
when you install the spacers can you take more pics of your rear end set up? right now im thinking about going with the same lift but still using the 2 inch coil spacers and front bj spacers that i currently have on my truck to give it a little more 6 inch in the rear 5.5 in the front, any pics would be greatly appreciated
Also can you snap a pic of the side of the truck when you add the spacer and your driveshaft angle?
#27
Here are the before and after pics
before
after
kinda hard to tell but the difference when its infront of you is very noticable
herea re the spacers i got off of trdparts4u.com
before
after
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
skoti89
07-06-2015 07:45 PM
