Rod bearing question
Old 03-17-2010, 09:29 PM
PirateMcgee's Avatar
Are the rods supposed to be able to move side to side along the crank like this? on a 22re
Old 03-18-2010, 07:25 AM
anyone?
Old 03-18-2010, 12:24 PM
coryc85's Avatar
Pirate - I think a little bit of movement in that direction is fine, especially on worn bearings. Are you thinking of replacing them? There are specs for the crank on movement in that direction, I guess it tells you if you need new thrust washers or something, but as far as I know, there is no "thrust" measurement for the rods. If that is your block and you have it down that far, sure would be easy to throw new bearings in there.
Old 03-18-2010, 01:22 PM
never mind guys I found the issues..........not bearings....see newest thread
glowz825
01-25-2022 09:28 AM
bigjstang
08-25-2021 12:41 AM
09-04-2015 09:27 AM
cgilley
07-25-2015 10:55 PM
ShakinIt2x
07-21-2015 06:20 PM
Quick Reply: Rod bearing question
