Replacing belt 94 P/U
Old 04-18-2006, 08:27 PM
rizzle1024's Avatar
I have a 1994 Toyota pick up and as you can kind of tell in the picture I provided, my belt is cracking and it needs to be replaced. I was wondering if anyone could tell me which belt this powers, and if it is possible for something with moderate skill to replace it. If anyone knows of a write up or a DYI on this I would really appreciate the link. Any help would be greatly appreciated. Thanks, Ryan
Old 04-18-2006, 08:40 PM
AH64ID's Avatar
alternator, and if similar to 22RE,the water pump... Pretty easy. On my re I have to remove the other belt, but its simple.....check out a chiltons manual..
Old 04-18-2006, 09:21 PM
runethechamp's Avatar
Question
Is there a good way of checking the belt tension if you don't have one of the weird belt tension meters?
Old 04-19-2006, 05:50 AM
snap-on's Avatar
Originally Posted by 4x4nala
alternator, and if similar to 22RE,the water pump... .
its not simular to the 22re. pictured is the 3vze, meaning the water pump is driven off the timming belt that is under the black plastic cover.
in order to replace the alternator belt you will have to remove the other 2 belts (if you have AC)
as mentioned before any hayes or cliton will outline the procedure.
or check out the online service manual. probibly have to look in the "general" mantinace section
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Old 04-19-2006, 06:20 AM
maxpower_hd's Avatar
An old mechanic once told me "Tight is tight, too tight's broke". That same guy used to tell me to tighten bolts "till the snap and back off a quarter turn".
The service manual tells all. If you get one it will be the most usefull tool you will have.
Old 04-19-2006, 06:07 PM
van7559's Avatar
All I can says is buy oem belts just changed the belts on me 94 22re and used the auto parts store ones, and not only did I have a problem getting the right belt, the belts are jusnk compaered to oem.
MMA_Alex
25
04-18-2017 05:07 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Tyler Cunningham
07-11-2015 10:18 AM
nick b
07-11-2015 04:38 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Replacing belt 94 P/U
