Replacement dome light switch?
Hi there!
I've owned a 1986 Pickup for a couple years now but I'm new to the forum. Anyone know where I might find another dome light switch? Mine appears to be worn out. It used to work here and there but has stopped all together now. I haven't found anything on eBay.
When my dome light stopped working, I scraped a little of the corrosion off of the contacts using a small emery board. It was free, took a few seconds, and super easy. A small strip of fine sandpaper might work if you can work it in there and get a little pressure on it.
Try this before trying to replace.
Thanks for the replies and ideas. I just took the whole thing apart and noticed that at some point the light's been left on, causing the plastic housing to bubble and warp. The warped plastic is causing the switch to lose contact. Looks like the prior owner put his own rivet in there, causing even more problems haha
Staff
You can get another dummy plug out of a 4Runner and move the connectors over to it. You can also replace the bulb with an LED and avoid the heat that comes with a standard bulb. Also I glue down my electric leads in the following link>>> https://www.yotatech.com/forums/f199...l#post52301576
I found a less than $5 replacement assembly that uses screws instead of rivets for the contacts. Far superior than OEM! The rivets and contacts showed lots of no-continuities when I checked them with my multimeter.
a
1993 3VZ-E Pickup
a
1993 3VZ-E Pickup
FS[PacNorWest]: 1986 Toyota 4Runner 4x4 V8
tyes
11
02-22-2016 09:18 AM
potterc32
11-23-2015 01:11 AM
vinman33
11-04-2015 11:53 PM
