Removing The 22RE
Old Oct 7, 2006 | 07:15 AM
4RunnerLVR86's Avatar
Question Removing The 22RE
I am going to remove the 22RE out of my 86 4Runner. What should I expect and look for. Also whats the easiest way to go about doing this. I already has teh head and intake/throttle body off.
Old Oct 7, 2006 | 08:28 AM
GrimReaper's Avatar
You taking the transmission as well? Truck stock or SAS
Not pulling the trans and stock here is what you need to do because you can't lift straight up.
Pull the access plate out of the passengerside fender for better access.
Pull the front plate.
Pull the cross member that the front diff bolts to.
LOOSEN THE CRANK BOLT NOW IF YOU WILL BE PULLING THE FRONT OF THE MOTOR OFF. Unless you have a good impact you will have trouble getting that loose once its out.
Loosen the rear mounts of the front diff so that it hangs down so as to give you oil pan clearance so you can move the motor forward off the transmission.
A/C hung off the fender
Pull radiator and put a piece of ply in to protect the A/C condenser in case the motor swings.
Pull the fan off.
Pull passenger side kick panel if you haven't already done so and pull the harness back through the fire wall. Its a LOT easier to mess with the plenum and harness on the engine stand.
Unplug the Alternator and associated wiring.
Two heater hoses by fire wall on driverside
With that access panel off in the ender you will see where its easiest to pull the fuel lines loose.
Battery cables
Unplug the transmission electrical if harness still on motor.
Pull liens off canister if still attached.
Exhaust at the junction the manifold and down pipe meet.
You already have the throttle cable off since the plenum is off.
If the sway is off hang an ratchet strap between the frame rails to support the bell housing. If the Sway is still in it will support it.
Remove the bolts around the bell housing.
Put a jack under the bell housing.
The trick is you need to lift it a couple inches and you need to keep the transmission in line with the engine. As long as they are in line it will slide right off. If they are not in line it will be a fight. Remember that when you reinstall.
Let the air out of the tires. Most hoists cant lift high enough to clear the coresuport.
If the transmission is coming out as well and a 5 speed pull it first:
Take the the bezel and shifter boots off. Take the shifters out. Stick your engine hoist through the passenger side door. Use a Tree saver and wrap it around the transmission at the shifter location (not the case at transmission). Thats the balance point with the factory cross member still attached. Need to level enough room to move the whole assembly back about 6 inches to clear the clutch.
Remove sway bar and bell housing bolts
pull slave cylinder
unplug the harness
The trick is to be able to support the transmission and case without the hoist hitting the windshield. You have to have enough slack to lower it. If you have a moving dolly slide it up under the mess once you wiggle the transmission off the motor. Lower it and roll it out on the dolly.
If you remove the transmission first you probably won't need to drop the diff to get the motor out.
Old Oct 7, 2006 | 12:36 PM
Its Stock IFS Auto Tranny. The Tranny is staying. I'm just pulling the motor only.
Old Oct 7, 2006 | 03:58 PM
Elton's Avatar
i did mine not that hard took aday by my self but some smart guy at toyota thought it would be a good idea to run the tranny cable down the middle of the lower intake manifold
Old Oct 7, 2006 | 05:46 PM
884runningless's Avatar
i just pulled mine for a minor overhaul and i had already had the head and oall the acc. off. It was a piece of cake. you can get to everything fairly easily with it all off. Mine is stock ifs but its a 5speed.
Old Oct 9, 2006 | 04:14 PM
aquamato's Avatar
pulled mine out in about 2 days. by my self, never did it before.. but stillhaving a problem getting it back in. i am thinking that the torque converter might not be in all the way. i can't get the bell housing to mate up with the block. any suggestions?
Old Oct 10, 2006 | 10:50 AM
How Much does it usally cost to rebuild a 22RE?
Old Oct 11, 2006 | 02:24 PM
dcg9381's Avatar
In my part of the world, $600-$800 depending on how much machine work you need.
See ted (engnbldr) for a great rebuild "kit" at a good price.
You guys typically pull it out with the wiring harness attached?
Old Oct 13, 2006 | 10:19 AM
4Hummer's Avatar
Take this
than Talk to ted at Engine Builder and do this
Complete rebuild into it for around $600 Canadian
and were talking, Pistions, rings, bearing, Water pump, oil pump, Timming chain cover, Timing chain and Steel guide, head bolts and other miss stuff
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
ItsJustD
Jul 7, 2015 07:49 AM
HRDC0R19
Jul 5, 2015 06:43 PM
