Remove rotor from hub
I have a 94 Toyota pickup 4wd v6 and I recently broke a stud putting the front tire back on after replacing from shocks. To easily remove the cone washers on the hub, is there a size bolt I can use to screw into the hub and pop the cone washers out?
Thanks, I suspected 8. Why else are those threads on the hub? I'm just a young vet trying to save some dough, don't know a whole heckuva lot mechanic wise.
The cone washers will lock down on load, so if they aren't ready to come out, pushing the mounting plate out (by screwing a bolt in) might cause them to lock.
Usually, you can convince them it's time to come out be gently smacking the side of the hub with a plastic-faced hammer. Or a piece of firewood if you're desperate. They'll rattle free, and you might need a piece of wire to hook-'em out.
Using an 8mm bolt will work great and super easy. Thread two bolts in evenly until the drive flange starts to separate from the wheel hub body. Once there is a bit of gap (1/16 inch or so) remove the two 8mm bolts and tap the drive flange back against the wheel hub. The cone washers will all pop right off. Don't forget to remove the dust cap and remove the gold bolt from the end of the axle half shaft.
That really works? I'll be damned. I don't even remember seeing any extra bolt holes.
Why would they not mention doing it like that in the FSM though?
I do know one thing. Pressing stuff off like that doesn't always go well. And, based on previous experiences, I'm not sure I'd even try it(much less recommend it). Threads get stripped. Bolts end up pushing on things they weren't meant to push on. There's been at least a few times I've thought removing something like that was a good idea...and it wasn't.
Hint: Those types of bolt holes are generally for pulling, not pushing. As in threading in bolts for attaching a puller tool.
Maybe. But there are a pair of threaded holes in the rear brake drums, and I'm certain they are there to "push" the brake drum off by tightening bolts into those holes. Trying to "pull" the drum off with a puller would be really difficult, because it would be twisting the drum (and jamming it) rather than evenly pressing it out on both sides.
Yep. I've stripped those exact ones trying to do just that. And you can attach a puller to pull them evenly actually. I've got a heavy duty slide-hammer with an "axle puller" attachment that will.
Do not have a copy of the FSM handy at the moment, but I thought I remember the way to remove those cone washers per FSM is with something like a flat blade screwdriver. There should be a slot that runs down the side of the cone washer. You take the screwdriver and place the blade on the edge of the cone washer where the slot is and give it a tap with a hammer and they pop out.
Cheers
Andy
Cheers
Andy
Pretty sure the FSM says to tap on the ends of the bolts(studs actually) with a hammer and brass rod. Possibly worded slightly differently.
The screwdriver trick is effective...usually. Definitely one I've used before.
Cheers
Andy
zammer
03-12-2016 07:00 AM
Dustin Egle
02-26-2016 03:48 PM
WTB[NorAtl]: WTB Lower Control Arm parts/Bolt 91 pickup
millennium falcon
02-22-2016 03:54 PM
