Redline MT-90
Old Sep 10, 2008 | 06:11 PM
highway's Avatar
Redline MT-90
would Redline MT-90 be the best fluids for my t-case and 5 speed trans ? (1989 4x4 pickup 195,000 miles)....if so who has the best deals ?
thanks,
Highway
Old Sep 10, 2008 | 06:18 PM
MMA_Alex's Avatar
Yes, Not a clue.
do a search if you want more peoples thoughts on mt-90
Old Sep 10, 2008 | 08:38 PM
Matt16's Avatar
My 5spd shifts nicely with it. Much better than before. 1600 posts! YEhaw
Old Sep 10, 2008 | 08:42 PM
tc's Avatar
tc
I get it from Summit Racing
Old Sep 10, 2008 | 09:00 PM
annoyingrob's Avatar
MT-90 is without a doubt, the best transmission fluid I have ever used in my R154.
I HIGHLY recommend it.
Old Sep 11, 2008 | 04:06 AM
highway's Avatar
thanks........... does it work well in the transfer case too ?
highway
Old Sep 12, 2008 | 07:30 AM
motoriderbc's Avatar
Transfer case uses GL-5 spec fluid so don't use M-90 it is GL-4
Old Sep 12, 2008 | 08:41 AM
crolison's Avatar
I use both in my tranny and tcase, and my rear diff.
I also got it from summit.
Old Sep 12, 2008 | 09:17 AM
thook's Avatar
You might be interested in reading this thread.....
https://www.yotatech.com/forums/f116...uestion-98830/
Old Sep 12, 2008 | 10:51 AM
tc's Avatar
tc
Actually, both the tcase and tranny are GL4/GL5. The problem with using a GL5 in the tranny is just that it's TOO slick and the synchros don't work as well.
I use GL5 heavy shockproof in my tcases to help quiet them down.
http://www.4crawler.com/4x4/index.sh...ntheticGearOil
Old Sep 12, 2008 | 11:48 AM
MMA_Alex's Avatar
gl-4 should be fine in the t-case, but I would recommend a gl-5 for the rear axle. gl-5 has better extreme pressure additives (moly? I think)
Old Sep 12, 2008 | 05:08 PM
Keith B.'s Avatar
Transfer is same spec as trans; MT-90 is fine. MT-90 is NG for diff, though---GL-5 only. Interestingly, Nissan specs GL-4 only for its truck transmissions.
Old Sep 16, 2008 | 04:16 AM
gilbert46's Avatar
I used mt90 and MTL 50/50 in both the tcase and trans, mobile 1 hypoid in the diffs. 235 on the rig and shifts perfectly smooth, big improvement over the initial notchy grinding and synchro clash into reverse
kazuya2416
Apr 5, 2024 02:17 AM
he's gone
7
Dec 3, 2019 07:08 AM
Pri$erulz
Nov 17, 2019 08:03 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
Bob_98SR5
24
Mar 2, 2004 09:33 PM
