Rear window relay temp fix
Old 04-26-2009, 09:06 PM
smallenginemechanic's Avatar
The rear window would not go up unless you pressed the button 100 times. No problem going down. I opened up the relay box and found the relay had burnt through the connecter so deep it wasn't contacting it anymore. I scratched the burntness off, and bent the tab down just a hair so it would contact again. Window works flawlessly. This is not meant as a permanent fix but as a temp untill you can follow matt16 https://www.yotatech.com/forums/f116/rear-window...runner-137193/ and his walkthrough.
06-01-2021 01:51 PM
Avenged
07-09-2015 07:55 AM
colinmil
07-06-2015 04:03 PM
coryc85
07-06-2015 04:07 AM
ptb12
07-05-2015 01:49 PM
Quick Reply: Rear window relay temp fix
