Rear window problems
Old Nov 14, 2007 | 08:55 AM
gray420's Avatar
Just put my top back on for winter. Last time I had it on was June and everything worked fine. All bolts are in, wiper harness is connected, and everything looks good. Wiper and window will not work from console switches. Am I missing something?
Old Nov 14, 2007 | 09:12 AM
TORTIS's Avatar
i know you made sure your connectors were clean, so does it work with the key?
Old Nov 17, 2007 | 08:29 AM
gray420's Avatar
It never worked with the key. I started to clean it up the other day and found a pile of dirt under the drivers side carpet. Seems that the windshield leaks down the drivers side in heavy rain. I never knew because it had the top off and I didn't drive it in the rain. So, i've cut out the carpet on the drivers side and bought some deoxit (hope it works, it was expensive) and i plan on going over all the electrical connections with it and checking wires. It'll be a good winter project and a chance to do some much needed interior work.
Old Nov 17, 2007 | 08:45 AM
4Crawler's Avatar
Have a look at the page below:
http://www.4crawler.com/4x4/CheapTri...arWindow.shtml
Old Nov 17, 2007 | 08:49 AM
gray420's Avatar
Thanks 4crawler. I have been to your page more than once. When I first got the truck the PO had a piece of plexi in for the rear window. using info from your site I figured out the top bolt was missing. Unfortunately for me, i don't think this one is going to be an easy fix.
Jun 1, 2021 01:51 PM
icentropy
Jul 11, 2015 07:21 AM
Jnkml
Jul 6, 2015 01:20 PM
coryc85
Jul 6, 2015 04:07 AM
