rear main seal leaks
I have a 93 4 runner that the rear main seal is leaking. cant i just pull the tranny and transfer case out to get to the seal. If you have any tricks let me know. Thanks
I checked the valve cover gaskets and they are not leaking. I just got done with replaceing the oil cooler o rings that where leaking. I was hopeing it was residual oil from that but it isnt. Thank you
Gravity is not your friend; EVERY oil leak will look like a main seal within a few seconds. I assume the OP cleaned his rig very carefully, and then looked for the leak.
it is very clear that the rear main is leaking. i cleaned everything and laid there under my rig and watch the oil start leaking from behind the cover plate. thank you for your time
couldn't find the thread I was posting in.
So I "redid" the rear main and I've had oil setting in there for a while...I didn't do it completely right apparently because well I'm still leaking some oil but now my truck is making a squeaking noise when it runs. It has oil in it but it's running really hot.
jerusry
10-19-2015 05:28 PM
