rear main seal
rear main seal
hey guy got a V6 that has a little oil leak very little im thinking it my be the rear main but not sure.
i dont know if its it but if it should i be worrid about it and is there away to find out with out pulling the trans and were are the V6 know to have oil leak
The valve covers are known to leak at the back, or just all around. Get a light and a mirror and start lookin. Id get some brake cleaner and wipe everything down, then after a few days take a look again and see if theres any new spots.
My oil pan gasket leaks so it makes it look like my rear main is leaking. If your rear main is leaking, you can get oil on your clutch and toast your clutch.
When I replaced my clutch the rear main looked brand new, im guessing this seal had 100k on it, but I replaced mine since i was in there. youve gotta pull the flexplate/flywheel to replace the seal by the way.
hey i did my clutch not to long ago but did not do the seal it looked new maybe it is the oil pan i lose about 1/4 to 1/2 a qurt of oil every 1200miles or so and the truck has 207000miles on it so is that about normal?
It could be that rear main. Check the valve cover gaskets first, those are easy to replace (you have to pull the upper plenum tho, its easy).
If its not your valve cover gaskets, or your oil pan, id pull the tranny again and replace that seal.
Do you see any oil spots under your truck?
one of the valve covers look ok one has a little oil but not much im hoping oil pan if it was the rear main woundet my clutch go out.
i looked were i park saw i little oil but my friend parked there with a rear end leak so idk if its mr or him
jerusry
10-19-2015 05:28 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
Iceman4193
07-15-2015 04:48 PM
