Really BAD Gas Mileage
#61
and wuts this seafoam??
#63
#66
1 Post
Just throwing this out there... My 94 22RE 4x4 has a 17 gallon tank. The gas gauge goes WAY lower than the E. With the needle completely on the left side of the E, I can usually still put in 15 gal. Haven't run outta gas yet.
And it sounds like the #1 injector was unplugged...
#68
Never assume anything. most places that install tires leave them at 40+psi.... for EVERY car.
And my guess would be that you have a bad fuel injector. or multiples. have you have them checked or tested them to be in good working order?
#69
One other thing to check in these absurdly low mileage issues is the fuel pressure regulator. If the diaphragm inside has deteriorated, you may be sucking raw fuel through the vacuum line... Just a thought.
John
John
pyramid
07-30-2015 10:05 AM
