Really BAD Gas Mileage - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
New! Use your Facebook to securely log into this site, click logo to login
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-22-2007, 10:58 AM   #1 (permalink)
4x4countrygirl's Avatar
Send a message via AIM to 4x4countrygirl
I have been averaging about 140 miles tops in my 4cyl. 94 p/u (15 gal. tank)...
I just bought it within the last month and I have had a full tune up done, we've replaced the EGR, seafoamed the engine and gas tank, had an 02 sensor replaced (the one before the converter) and cleaned out the throttle body and AFM. The VSV wires have been replaced because the wires were stripped and frayed. With all that done... my gas mileage is still super sucky. I thought at least one of these things would clean it up. What could I be missing that could really be causing such a loss in gas mileage?
-and-
I had a full diagnostics test done and my check engine light went off when we replaced the EGR but the weird thing to me is that we could not find an 02 sensor after the converter... is there one after on this model and year?
__________________
'94 Pickup
22RE/5sp/4x4
4x4countrygirl is offline
Old 02-22-2007, 11:01 AM   #2 (permalink)
Injohneer's Avatar
Not sure on the P/Us but my '95 4Runner only has one O2 snsr - I'm pretty sure they didn't go on most vehicles until '96 or later.
I'll just throw these out there - how's your cat converter? you'd probably notice other symptoms first, but I thought I'd mention it.
__________________
Trail/Build Rig: 1981 Toyota Pickup 4x4, flatbed
Tow Rig: 2001 Chevy 2500HD Duramax 4x4, X-cab Long Bed. Will be my tow rig, when I get a trailer.
RIP: 1995 4Runner.
Injohneer is offline
Old 02-22-2007, 11:02 AM   #3 (permalink)
MudHippy's Avatar
Sorry if this is an insult to your intelligence, but I'm always suprised at how many people don't keep thier tires inflated to max, big difference, esp. with over-sized.
MudHippy is offline
Old 02-22-2007, 11:10 AM   #4 (permalink)
Just got new rims and tires put on last week... so they were just mounted and balanced and should be properly inflated.
__________________
'94 Pickup
22RE/5sp/4x4
Old 02-22-2007, 11:22 AM   #5 (permalink)
Bear80's Avatar
Send a message via AIM to Bear80
how's the engine on power, have you noticed a loss in power?
__________________
1986 Truck - Monster IFS
1997 FZJ80 - Locked, Lifted, Ready
Range Rover Recovery Vehicle
Bear80 is offline
Old 02-22-2007, 11:23 AM   #6 (permalink)
I forgot to mention that my rpm's drop and go up while I am idle. When it's normal it usually idles around 1,000 rpm but sometimes it will fluctuate from 1-1500 rpms until I rev the engine and it drops to normal again. Sometimes it will even drop so low in idle it reaches around 5-600 rpm. What could this possibly be?
__________________
'94 Pickup
22RE/5sp/4x4
Old 02-22-2007, 11:25 AM   #7 (permalink)
trythis's Avatar
It could be that your thermostat needs replacement. There could be a problem with the cold start injector not turning off. You could also have a temperature sender that is bad.
Check your TPS to make sure it is working. and make sure your throttle body closes all the way.
CA trucks-4runnres have 2 ox sensors
__________________
89 DLX xtra cab 4x4 22re Auto with 210,000, 225 75R 15, Stock except, "new" 2000 toyota cd/radio, rear speakers hidden in the back seat, SR5 instrument cluster, factory clock. dead aftermarket cruise and some matching blue door pockets! New timing chain with Engine builders front end rebuild kit. Tokico RT trekmaster shocks <-like them.
I found the turtle in my yard, after mowing over it and it was fine! Old toyota trucks are like turtles: slow, steady and durable.
trythis is offline
Old 02-22-2007, 11:29 AM   #8 (permalink)
Chapman88SR5's Avatar
Send a message via AIM to Chapman88SR5
If we, Im her boyfriend =), unplug the cold start injector, what would happen?
__________________
1988 4Runner 3.Slow
-33x12.5 Mickey Thompson Baja MTZ Radials
-4Crawler 1.5" BJ Spacers
-OME 2" Leaf Springs
-Flowmaster 44
-Engine replaced at 200k
-Green Rattle can paint
The early bird gets the worm but the second mouse gets the cheese. Hmmm...
See more in the Check out my Truck section
God works through Christians; I am a Christian.
-George W. Bush
Chapman88SR5 is offline
Old 02-22-2007, 11:46 AM   #9 (permalink)
Quote:
Another thing I failed to mention... I need to get better at these post things! But yes, I feel like there is power lacking. I know I'm not going to get a lot of speed/power out of a 4cyl, but I also know that it feels like there is something almost "blocking" it from it's full potential.
__________________
'94 Pickup
22RE/5sp/4x4
Old 02-22-2007, 12:38 PM   #10 (permalink)
MudHippy's Avatar
That makes me think fuel filter, gotta do'em every 60k. I aint sure about the cold start injector causing anything like that, maybe so. I would think if unplugged it would be harder to start, esp. when amb. air temp is low. It should help the idle, and substantially the power, if it's needed, the filter.
MudHippy is offline
Old 02-22-2007, 12:40 PM   #11 (permalink)
misterzee's Avatar
Send a message via Yahoo to misterzee
Quote:
OMG ! Don't do it!! Not while your loved ones are near!! J/K
The cold start injector sprays extra fuel in there only when the engine is cold, there is a timer that kicks it off a short time after the engine is running. You can unplug it. Might make it a little 'cranky' when cold.
check: tire pressure, ignition timing, make sure the catalytic convertor is not plugged, clean air filter, make sure the brakes are in good condition and properly adjusted, I have had more than one instance of brake cylinders grabbing intermittently...
My 22re will idle up and down a bit, specially when the weather is COLD, I suppose due to linkages not moving as freely as they do when its warm.
__________________
85 SR5, 87 SR5 (SAS), 88 DX (on loan),
96 4Runner 2.4L, 96 4Runner 3.4L,
all males... and they all RUN!
2003 Chrysler Town and Country LTD... female
it runs too :)
CLIK4PIX
misterzee is offline
Old 02-22-2007, 01:08 PM   #12 (permalink)
91TPU's Avatar
Send a message via AIM to 91TPU
-and-
sensor should be before the converter, not after...some vehicles have them in the converter...but on my truck(i know all years arent the same), my 02 sensor is about a foot or so before the cat converter..
__________________
87' 4runner...22re...31" Bridgestone Dueler AT-New project rig and winter dd.
91' 3vze...190k...31" BFG All Terrain's...K&N FIPK-SOLD
07' Civic Si-The Daily Driver.
Quote:
Originally Posted by Sonofmayhem View Post
god hates you.
91TPU is offline
Old 02-22-2007, 01:11 PM   #13 (permalink)
Send a message via AIM to fork
checked for vacuum leaks?
fork is offline
Old 02-22-2007, 01:32 PM   #14 (permalink)
pruney81's Avatar
140 is horrible for a 22re, maybe a valve adjustment? You should be getting a hundred more miles to that tank at least. I don't think just swapping a fuel filter in there is gonna solve this problem. Although I don't any suggestions
pruney81 is offline
Old 02-22-2007, 02:49 PM   #15 (permalink)
Schralper's Avatar
What size? If they're BIG badazz tires. You're mileage is gonna suck!
Though gears will help.
Schralper is offline
Old 02-22-2007, 02:59 PM   #16 (permalink)
The tires are bigger, but not enough by far to cause that kind of gas deficit... they are 31x10.5
__________________
'94 Pickup
22RE/5sp/4x4
Old 02-22-2007, 04:24 PM   #17 (permalink)
pruney81's Avatar
So you're getting 9.3 mpg on a 22re? Are you sure you're calculating it right? I've got a 95 3.0 auto 4Runner with very loud valves and the original fuel filter and I'm geting about 14 mpg around town. I know in my old 86 22re I was getting around 20. I hope you figure it out
pruney81 is offline
Old 02-22-2007, 04:31 PM   #18 (permalink)
trythis's Avatar
I think yu are just gonna have to go through the sensors and test them. Replace all your vasuum hoses and clean out the metal lines while you are doing this.
__________________
trythis is offline
Old 02-22-2007, 05:21 PM   #19 (permalink)
How do you go about cleaning the metal lines? Replacing the vacuum lines doesn't seem that bad. Any tips on checking all the sensors? Just use a test light or ...?
__________________
1988 4Runner 3.Slow
-Flowmaster 44
-George W. Bush
Old 02-22-2007, 05:38 PM   #20 (permalink)
Staff
UKMyers's Avatar
Send a message via AIM to UKMyers
Use a multimeter to test voltage at the plug of your sensors. Last 22RE I seen with the fluctuating idle had a bad O2 sensor. Also just because a tire shop installed you tires means NOTHING on inflation pressures. I have seen all 4 have different pressures that varied vastly from one another coming out of a tire shop. It will not cause that bad of mileage like your getting but I'd check them anyways. I always ran 33psi in my 31's.
__________________
2006 Tundra Double Cab TRD Offroad 4.7 IForce Bilstein 5100's, 285 BFG's, Panther Wheels, Limo Tint
1994 4-Runner SR5 5 Speed SASed, Detroits, Armored, Dual Cases, 37" MTR's Build up http://www.yotatech.com/showthread.php?t=104000
Need Toyota Parts? www.davezoffroadperformance.com
Quote:
...why does my IFS have no flex, and what can I do to make it flex???
UKMyers is offline
Old 02-22-2007, 05:46 PM   #21 (permalink)
Which one?
__________________
1988 4Runner 3.Slow
-Flowmaster 44
-George W. Bush
Old 02-22-2007, 05:52 PM   #22 (permalink)
Staff
UKMyers's Avatar
Dude if you dont' have a multimeter and dont' even know which one you would need you should take that truck to a shop now and save yourself some trouble. Did they bother to pull the code during the diagnostics test that was mentioned? I'm guessing it had nothing to do with that EGR valve.
__________________
UKMyers is offline
Old 02-22-2007, 06:24 PM   #23 (permalink)
trythis's Avatar
ANy multi meter will do. You gotta start somewhere learning how to work with them. The really cheap ones will fail eventually, but get what you can.
The Factory shop manual will be your friend. Checking the sensors requires removing them, running diagnostics according to the FSM. IT takes time, but it is very easy.
__________________
trythis is offline
Old 02-22-2007, 06:49 PM   #24 (permalink)
Quote:
"Dude" I'm sorry I have never used a multimeter before. I am pretty sure I could learn how to use one with the proper guidance rather then telling me I am useless and to go to a shop. But thanks a lot! Its people like you who shouldn't be on this site. I guess learning how to install my own clutch and even my engine, means I can't learn how to use a multimeter.
trythis,
I have cleaned all of the sensors but still have yet to check them. You wouldn't happen to have the FSM on a PDF file for the 22RE would you?
__________________
1988 4Runner 3.Slow
-Flowmaster 44
-George W. Bush
Old 02-22-2007, 08:23 PM   #25 (permalink)
notanymore's Avatar
as far as a multi meter just go to sears or where ever works for you and one up for like $15-$20, it doesnt matter too much which one you get, they are not that hard to use so im sure you could figure it out
notanymore is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Bad gas mileage hopper 95.5-2004 Tacomas & 96-2002 4Runners 13 07-21-2007 07:42 AM
Bad gas mileage (bad catalytic converter?) Help!! zberch 95.5-2004 Tacomas & 96-2002 4Runners 4 07-15-2007 10:08 AM
really bad gas mileage hubie 86-95 Trucks & 4Runners 4 01-24-2007 11:20 PM
very bad gas mileage toyfreak 86-95 Trucks & 4Runners 6 07-17-2006 06:13 PM
How bad does gas mileage get when... JTB82 95.5-2004 Tacomas & 96-2002 4Runners 2 11-28-2002 06:03 PM
Contact Us - YotaTech - Archive -
Top
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2010 InternetBrands, Inc.
