Rattle coming from area of transmission
I am driving a '91 Toyota Pickup with a 22RE and a stock manual 5-speed. A day or so ago I heard a metal on metal rattle coming from what I thought was the exhaust (thought bolt was coming loose, forgot to thread-lock some). The other day I went under to fix it but nothing was loose anywhere I could see. So I turned the engine on to find the rattle, turned out to be coming from the transmission. I think and hope it is just a sheared off gear tooth from a bad grind (teaching girlfriend how to drive stick). The drive train has about 145K on it. Any advice?
It makes noise all the time, less with the clutch engaged. I'm not sure about when under load because the sound of the exhaust over powers the sound of the rattle.
Did full inspection, no noise when clutch is not engaged (after cool down period of a few seconds, even if moving). Noise is constant no matter the load and is only there when clutch is engaged
BeMiceElf
10-10-2015 09:40 PM
FS[PacNorWest]: Factory Alloy Wheels - Bay area
94whiterunner
9
09-22-2015 07:28 PM
rushw
07-18-2015 01:46 PM
mengquis
07-13-2015 10:39 AM
