Rancho rs5000
Old 02-22-2009, 06:38 PM
mattaway's Avatar
Rancho rs5000
I've got a '92 4x4 pickup. It's stock height. I found Rancho rs5000's for the front, but for the rear they only listed shocks for the 2wd, or the 3-4" lift.
I know a stock 4x4 is about 3 inches taller than a 2wd truck. So I'm guessing the 2wd shocks are too short, and the 3-4" lift ones are too tall.
I guess my question is which should I get? Do they make a stock 4x4 shock? Am I SOL?
Old 02-22-2009, 06:50 PM
abecedarian's Avatar
shop elsewhere.
Rancho makes shocks for the stock trucks.
every catalog I've looked at lists Rancho at 0-1" lift, 1-2" lift, 2-3" lift, 3-4" lift.
Old 02-22-2009, 06:51 PM
Fink's Avatar
I highly doubt the 2WD trucks are 3" shorter than the 4x4's - that's a HUGE difference.
Are you set on the Rancho's?
I'd look into some OME's if it were me - I'm a huge fan.
Fink
Old 02-22-2009, 06:57 PM
mattaway's Avatar
I went to Advance. I'll try looking somewhere else. Thanks.
Old 02-22-2009, 06:59 PM
mastacox's Avatar
Fink
They are absolutely that much different, if not more. Look:
2WD:
4WD:
Old 02-22-2009, 07:00 PM
Fink's Avatar
If I were you I'd shop around online.
I've always found better deals online than I have anywhere locally.
Fink
Old 02-22-2009, 07:01 PM
Fink's Avatar
2WD:
4WD:
Learn something new every day.
Fink
mattaway's Avatar
2wd:
Extended Length (in): 14.370 in.
Collapsed Length (in): 9.120 in.
4wd:
Extended Length (in): 22.375 in.
Collapsed Length (in): 14.125 in.
That's a HUGE difference....
Old 02-22-2009, 07:14 PM
seanmearse's Avatar
should have just posted here first. when i go into work tomorrow i will call rancho's vendor line and see what they say, or if they have a part number for the right shock.
jaretstuff
10-22-2015 05:25 PM
adamk
09-24-2015 03:59 AM
adamk
09-23-2015 03:24 PM
PirateFins
05-29-2003 05:49 AM
Quick Reply: Rancho rs5000
