radio and weird problems with electrical
Old 09-27-2008, 03:15 PM
Countryhick's Avatar
If im driving and use my blinkers to turn left or right. everything twitches.
and if my trucks not on and i just am using the radio i turn it up to loud it cuts out. everything restarts
anybody got any ideas on where my short would be or wat it could be???
Old 09-27-2008, 04:16 PM
Matt16's Avatar
I had exactly the same thing happen, I was thinking there was a really weird glitch in the electrics. Nope. My alternator was dying and not properly recharging the battery. After buying a new battery, I discovered that it was the alt. I then bought replacement brushes (~$10 from the parts store) and installed them myself. This fixed the problem.
First though before jumping to conclusions,
  1. clean off the battery terminals
  2. make sure your grounding straps are making contact
  3. have your battery tested at a parts store
Your battery will show up as not holding a charge unless you charge it completely before testing it. I didn't know this and unnecessarily bought a new battery.
If it does turn out to be the alternator, I'd be surprised if it weren't the brushes. It's an easy job to do yourself, and there is plenty of information on fixing it already out there.
Old 09-27-2008, 04:21 PM
HAVOC's Avatar
Check your body ground (the little wire from the negative battery terminal to the inner fender). This wire breaks alot (Toyota made it too short, so when you do any battery work it gets pulled on alot). I've seen some electrical problems because of just this.
jasonty
41
12-23-2018 01:00 PM
Yota.Jay
07-23-2015 08:08 PM
v_man
07-23-2015 04:01 PM
mtb_taco
07-15-2015 08:36 AM
icentropy
07-14-2015 10:23 AM
Quick Reply: radio and weird problems with electrical
