Radiator cap wonders
Old 10-31-2007, 12:16 PM
Luvmeye22re's Avatar
Got one on the way, tried to get to the parts store, this time it got pretty warm so I turned around and came back.
Old 10-31-2007, 12:43 PM
Ok well I smashed down the ears that tighten the cap on the rad. and it sits a lot tighter now, so the only left to do would be to see if the spring is weak and blows a bunch of into the overflow right? And of course a new rad next week but for now just want to make the 10 mile drive to work and back so I can make the money to get the rad. I really need to start working full time. Anybody around breckenride Colorado need an employee?
Old 10-31-2007, 12:57 PM
Haha, I don't think it even needs a radiator that bad, after I hammered down the ears on the radiator cap and re-installed it I drove the piss out of it up I-70 and it didn't even get quite to halfway warm, when this morning it made it about 3 miles of easy downhill driving before it was almost to the top white line on the guage. I guess it pays to be a redneck with a big hammer lol.
Old 10-31-2007, 01:05 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
How 'bout that? Looks like things may have just gotten a little easier. Yeah man.
Old 10-31-2007, 01:10 PM
  #25
MMA_Alex's Avatar
hammering rad cap = $1500 savings on a used truck i guess lol
if you're gunna keep that rad i'd atleast do a hell of a flush if you can see big chunks floating in it. get as much of that crap out as you can
Old 10-31-2007, 01:26 PM
  #26
Yeah, that means I have more money to spare now, woohoo, one step closer to a lift.
I'm still getting the new radiator next week, but atleast I'll be able to get there to buy it.
Old 10-31-2007, 01:35 PM
  #27
surf4runner's Avatar
it doesnt matter who ya are, as long as you have a BFH (and duct tape)
my favorite CO shirt is I70 w/a red line through it.
Old 10-31-2007, 04:17 PM
  #28
just a 22re's Avatar
i dont get the 170 with a red line though it people
Old 10-31-2007, 09:24 PM
  #29
Dammit did it again, I hate cooling problems. They affect everything, going to the parts store, going to the gas station....I hope that replacing the radiator eliminates this. This time the upper hose was hot, the lower hose was cold, the over flow bottle was full of hot coolant and air was bubbling through it, and the radiator took a gallon of water almost. 15 mile drive. I hate cooling issues. Heater also goes from hot to cold, hot to cold.etc. Looked at the block plug, has fresh teflon on it, so I'm guessing it was part of the flush, worried about a head gasket.
Old 11-01-2007, 05:36 AM
  #30
mt_goat's Avatar
That could be your thermostat not opening, or a blockage in the radiator, but since it comes and goes I'd say the thermostat. Is this a 22re or 3VZE? If its a 22re look at this:
http://www.4crawler.com/4x4/CheapTri...tml#Thermostat
...the over flow bottle was full of hot coolant and air was bubbling through it.
This could be a blown HG or the water in your head boiling. You need a pressurized cooling system if you're running water with your antifreeze to stop the boiling, especially at high elevations, did you try a new radiator cap yet? And please don't tell me you're running 100% water for coolant! The antifreeze % raises the boiling pt as well as protecting from freezing. You should be running at least 50/50 mix of antifreeze with water at high elevations.
... Heater also goes from hot to cold, hot to cold...
This could be from air in the system, ie.. losing coolant or boiling water. Probably a side effect of your main problem.
Old 11-01-2007, 03:09 PM
  #31
Bingo, I took out the thermostat on my lunch break today and it ran cool, if not damn near cold on the way home. Hopefully it will be ok for a few more days until I get the radiator and a new thermostat. I'm not usually on the "must be OEM" kick, but I think I will get an OEM thermostat.
Old 11-01-2007, 03:25 PM
  #32
Oh, and it looks to be mostly coolant, and relatively fresh, it was green lol. Just got the truck so I don't know every little problem quite yet. I will be flushing it really good with the old radiator and draining the rad and the block dry and starting from scratch on the coolant situation. The P.O. said he put the new head on a few years ago, so I really don't think it's the HG, but since it is having cooling problems, he could have toasted it too. I haven't let it get that warm, it doesn't seem to get all the way to the top white line on the guage and barely boils over, but it isn't flowing like it should, that much is obvious. If it is the HG, it's motor time, I don't want to screw with that much work when the truck potentially has WAY over 210k miles. The OD is stuck at 210k and he said it's been that way for the past 2 years since he bought it. (broken speedo)
Sleaker
08-26-2020 06:03 AM
the1998sr5
15
07-14-2020 08:35 PM
the1998sr5
07-16-2015 06:20 AM
Poncho0206
07-10-2015 06:21 PM
horunner1x
07-10-2015 06:33 AM
Quick Reply: Radiator cap wonders
