R134 Freon Pressure in a 1994 P/u
Old 06-26-2013, 03:07 PM
1994Toyota4X2's Avatar
What is the factory recommended PSI for the high and low pressure lines on a 1994 Toyota P/u a/c system?
Old 06-28-2013, 07:55 AM
Bump Bump
Old 06-28-2013, 08:11 AM
rustypigeon's Avatar
Does your '94 not use R12? Was it retrofitted for R134?
There should be a sticker in front of the radiator telling what refrigerant and what pressure.
Old 06-28-2013, 10:16 AM
The sticker says R134A but I don't see a capacity listed. I believe the truck came with R134A from the factory. I've had it since 1995 and don't recall changing it.
Old 06-28-2013, 10:20 AM
I must have one of the last '94 trucks with R12 then. I have specifications for R12, but no info on the R134 systems.
If it helps, the R12 systems shows 26.45oz. +/- 1.76oz.
Rickstwowheels
09-09-2015 06:12 PM
Scotto6591
09-03-2015 07:38 PM
Scatterbrain
09-03-2015 06:46 PM
DiggnDeep
09-03-2015 02:45 PM
dguzzi
09-03-2015 08:48 AM
Quick Reply: R134 Freon Pressure in a 1994 P/u
