R12 OR 134a
Old 06-22-2008, 08:54 AM
goolsby7mm's Avatar
R12 OR 134a
I have a 94 ex-cab 3.0, what era A/C system do I have, 134a, or the older R12?
Old 06-22-2008, 09:41 AM
Dirtoy4x4's Avatar
Mines a 94 3.0 and its R12.
Old 06-22-2008, 10:36 AM
anotherjeff's Avatar
What difference does it make?
If it was that important, you could open the hood and explore. Or, take the VIN to a dealer.
That said; '94-'95 was the era of the switchover, so your '94 might be either. So the advice stands.
Old 06-22-2008, 10:41 AM
abecedarian's Avatar
IIRC the schrader valves are different between the two so if you can determine which is which, that should point you at the answer.
Old 06-22-2008, 11:03 AM
1990Runner's Avatar
there are stickers that let you know under the hood
Old 06-22-2008, 12:38 PM
goolsby7mm's Avatar
Well the PO must have removed whatever stickers once existed because there is no sign left. I guess I'll run my VIN through a dealer. Thanks.
4runner fanatic
07-11-2023 11:18 AM
nanhodges2733
05-29-2020 03:28 PM
highonpottery
09-14-2015 12:46 AM
DiggnDeep
09-03-2015 02:45 PM
klavender1
08-15-2015 01:51 PM
Quick Reply: R12 OR 134a
