Quick Question: oil pump removal procedure 3VZE
Old 10-15-2008, 03:00 PM
gtfourdreams's Avatar
when removing the oil pump, do i have to remove the oil pan too? (i already have the crank pulley, timing belt, t-belt covers, and water pump all removed.)
this is an 89 4Runner with the V6 5spd. all factory, no mods.
Old 10-15-2008, 03:03 PM
dlbrunner's Avatar
yes, you need to pull the pan
Old 10-15-2008, 04:05 PM
damn! i was hoping i didnt have to. so... whats the easiest way in the garage? drop the front diff i suppose?
Old 10-15-2008, 04:17 PM
jason191918's Avatar
That's what I did...although I have heard you can unbolt motor and jack that up.
What I did was unbolt diff, vacuum lines, and front crossmember (that diff bolts to) and left the axles hooked up.
This worked well for me, but I also had the tranny/flywheel off.
bigjstang
08-25-2021 12:41 AM
Colington
03-08-2020 09:51 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Cplmike
07-08-2015 08:47 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Quick Question: oil pump removal procedure 3VZE
