quick gearing question??
Old 04-20-2009, 10:12 AM
90veezee3's Avatar
I searched and couldn't find my answer. I've never geared a truck before seeing as how this is my first toyota. Do you usually gear front and rear or can you just gear the rear? I'm planning on going with some bigger tires (found a link on here with a list of all the gears for different tire sizes wich was very helpful) and i'm just wondering if i can get a way with gearing just the rear. Thanks and much appreciated.
Old 04-20-2009, 10:45 AM
894x4pickup's Avatar
You could...
but then the rear tires would spin faster than your front, and binding/breaking/stripping can occur...assuming its 4wd...so simple answer: NO! GEAR BOTH!
Old 04-20-2009, 10:47 AM
totally a bro
Staff
vital22re's Avatar
front and rear must match
Old 04-20-2009, 10:53 AM
Bobzombie's Avatar
if you never use 4wd then technically yes you could. But you shouldnt Its a bad idea
Old 04-20-2009, 11:12 AM
mattaway's Avatar
good way to tear up your t-case.
Old 04-20-2009, 11:26 AM
swapped89's Avatar
You can just do the rear if u never use 4wd. If you put it in 4wd with different gears in front and rear something WILL break! But assuming u want to use 4wd since you are getting bigger tires You do have to gear both front and rear the same so that all tires spin the same speed.
Old 04-20-2009, 03:03 PM
90veezee3's Avatar
Alrighty thank you all, i appreciate it and that's what i figured. i'm still learnin haha. now where can i get a good matchin set of 4.88's?
Old 04-20-2009, 05:20 PM
www.gearinstalls.com
Zuk is a member on here...
Or if you really lucky, any 90-95 3.0 V6 and an auto tranny with a factory 31" tire package will have em...good luck!
Old 04-20-2009, 05:35 PM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Correction, any '92-'95 3.0 V6 auto will have 4.88s. My '91 came with 4.56's.
Old 04-20-2009, 08:51 PM
ARRG...thats what i meant...
oldirtydirt
02-23-2020 09:30 AM
jasonty
41
12-23-2018 01:00 PM
mskalmus
05-28-2017 07:51 AM
icentropy
07-14-2015 10:23 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: quick gearing question??
