Problems Starting My 87 4runner
Old 04-03-2007, 11:40 AM
darylb13's Avatar
I Got My 4runner Stuck In A Mud Hole And Flooded The Passenger Side. I've Replaced The Ecu, Starter Relay, And Solenoid Resistor.
Now It Starts But It Only Starts Sometimes. It Has Trouble When It's Cold. When It Starts It Idles Very Rough It Seems Like The Timing Is Off, But If I Rev It Up It Cleans Up And Runs Fine. I've Checked Fuel And Spark And Have Both. I'm Out Of Ideas Some Help Would Appreciated.
Thanks,
Darylb13
Old 04-03-2007, 11:43 AM
rdlsz24's Avatar
22RE or 3.0? EFI or carb?
Rob
Old 04-03-2007, 06:46 PM
drew303's Avatar
87 4runner, probably 22RE? ... and you replaced an ECU so its EFI for sure.
=P
Old 04-03-2007, 07:07 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Did you check all the fuses? Maybe something is shorting out?
Old 04-09-2007, 12:05 PM
darylb13's Avatar
it's a 22r efi, i checked the cold injector and it sprays so now i'm going to change the throttle position sensor, then after that i'm out of ideas
Old 04-09-2007, 12:07 PM
darylb13's Avatar
22re efi 5 speed 4x4
Old 04-09-2007, 12:18 PM
rdharper's Avatar
How far into the engine compartement did the water get?
Old 04-11-2007, 06:13 AM
darylb13's Avatar
i flooded the half the engine bay on the passenger side
Old 04-11-2007, 07:42 AM
rdharper's Avatar
Ok... so what does that mean. Did the water cover the relays on that side? I assume no water could have gotten inside the engine, right?
What you've described so far doesn't add up. Missing info.
Old 04-12-2007, 08:22 AM
darylb13's Avatar
your correct, the air intake was not under water, and i've changed all the relays on the passenger side.
Crazychris1871
06-27-2016 10:38 AM
vasinvictor
01-20-2016 12:39 PM
Ichneumon
09-27-2015 04:21 PM
torgeir
06-25-2015 05:26 AM
alyssa
06-30-2002 01:33 PM
Quick Reply: Problems Starting My 87 4runner
