Pressure plate
The spring does look a little flat.
The pressure plate bolts need to be torqued to spec in order to insure that they don't come loose, but if you have already tightened them enough to pull the pressure plate down tight to the flywheel,
it's not likely that further tightening will raise the pressure plate spring.
Are you sure that the pressure plate and friction disc are correct for your application??
The friction disc is in there right???
Damn if i have to pull trans back to loosen and spec tight te bolts wat a biotch...hope someone can fill in
To much this trucks been killing me with the clutch
Curious..." Flywheel bolts are a different story". A little bit different? A lot different? How and why, if you don't mind? Why wouldn't it be important to torque pressure plate bolts, if that's what you're implying?
Im just wondering are the forks suppose to be like that on the pressure plate i didnt touch the flywheel...so are the pressure plate forks right ?
Correct tightness of some bolts is critical because of the catastrophic, often expensive, or dangerous, nature of loosening or failure.
Fasteners for con rods, main bearings, flywheel bolts, head bolts, steering gear, ect.............
Once you are a mechanic with long experience, some things just come naturally, like proper tightness of various sized, less critical, fasteners.
Inexperienced wrench turners should torque every fastener that they can find a torque spec for, til they have good confidence in their judgement and ability.
Some folks never get it.
I just bought a truck where every fastener that was'nt twisted off, was loose.
I replaced my clutch a couple of years ago and everything was torqued to spec. I suggest you do the same cause you don't want to have to take everything out again to redo it if something goes wrong. Do it right the first time.
Yes i know but dont u think 14 ft lbs is not enough for something thats constantly spinning if its spinning all the time u wouldnt want it to get loose...too late on taking everything out i have done it 3x already its all hooked up trans on front and rear shafts etc..i been googling and i see pics where the plate sits like how mines sitting well i wouldnt know yet untill i try it out got to hook up master and bleed slave
If THE BOOK says 14 ftlbs (kudos to you for at least looking up the number), that's what you should do. They aren't really hefty bolts; if you over tighten them they will break. Maybe not while you have it out on the bench, but soon, and at the worst time possible.
14 ftlbs isn't a lot; I don't think I could get real close "by feel." That's why I have 3 torque wrenches (1/4", 3/8", 1/2"), so I can hit the small torques as accurately as the big ones. (and, for what it's worth, I have them calibrated.)
I give you more credit then that.
I don`t think I saw my Torque wrench since my last engine build years ago see the case quite often.
The thing is if you have doubts until you do what you feel you need to fix the problems they are not going away
Then if your going to torque things new bolts into a new fly wheel
Not to sound rude, but are you able to use the tranny normally? Perhaps you are over thinking this or you are very anal (which can be a good thing when it comes to cars) but can also cause unnecessary headaches. I cannot figure out how overtightening the bolts on the pressure plate could deform the forks, I dont think it is possible at all. Some pressure plates have shaped tips on the end of the fingers and some are flat. There is no way you can deform the fingers IMO. If something wasn't right you would not be getting the truck into gear.
I say forget about it. I also do not use a torque wrench on the majority of the things I repair and unless you really don't have a sense of "tight" and "over tightened" then you should be just fine.
