Power steering line question
Old 05-21-2012, 06:33 PM
Mcoman's Avatar
I have a 1993 pickup with a 4 cylinder 5 spd and I have a power steering line leaking from the pump to the rack and i can't seem to find it anywhere the line is about 12in long. Any help would be great. Thanks
Old 05-21-2012, 06:38 PM
waskillywabbit's Avatar
Clean it off. Pressure wash it. Let it dry. Baby powder it. Crank it up. You should find your leak.
:wabbit2:
Old 05-22-2012, 12:43 AM
wyoming9's Avatar
Wink
You can`t find the leak ??
You can`t find a line to buy??
:jessica:
Old 05-22-2012, 04:58 AM
Mcoman's Avatar
Sorry I can find the leak I can't find what line it is exactly when I look for it to buy. I think it is a return line
Old 05-22-2012, 05:29 AM
JayKray's Avatar
I just had a very similar problem in my 93 and found that it was a rusted out power steering cooling loop that goes out in front of the radiator. fluid was running down the line and getting blown around by the fan, so it was a little tricky to find where it was originating. As others mentioned, clean it up and look for the newest wet spot.
Old 05-22-2012, 05:34 AM
Mcoman's Avatar
Yeah I no where it is leaking I am just not sure what line it is it might be the return line or a cooling line like you said
Old 05-22-2012, 07:57 AM
James Woods's Avatar
The return line will be held on with hose clamps or some type of clamp, my guess is that it is your pressure line and this will be bolted into the pump and the steering gear box. If it is just your return line, you can get bulk hydraulic hose from the parts store for cheap.
Old 05-22-2012, 08:13 AM
Mcoman's Avatar
Yeah it is bolted to the pump and steering box. Thanks
Sleaker
08-26-2020 06:03 AM
87turboPA
07-12-2015 07:49 AM
jon.r
07-11-2015 03:34 PM
87turboPA
07-09-2015 05:58 AM
skoti89
07-08-2015 12:05 AM
Quick Reply: Power steering line question
